Question about Dell ST2310 23 inch LCD Monitor
My lcd works fine untill i flip upside down
I bought a refurbished Dell ST2310 and after a month it started giving me dim display.. after keeping it on for 2 minutes it start acting like switching between 100% brightness to 20% brightness repeatedly with no uniform pattern.. i disassembled the lcd monitor and plugged the power cord in and placed the lcd up side down (not intentionally), it was working fine untill unless i flipped it back to its normal position.. so i found by repeating the process few times that my lcd is working absolutely fine upside down.. please tell me what the reason and is there any user replaceable part in it so i can get it fixed ? thanks, many regards, Basit Zia
  • Basit Zia Jul 24, 2013
    last night i disassemble my lcd monitor and discovered that there are 2 wires plugged into the power supply board from which one on them was glowing purple like some magic sparkle and the wire was warm.. after playing for hours with that i figured out that touching that wire make back light goes on and off..
  • Hassel Lee
    Hassel Lee Jul 25, 2013
    It means you need to change the power cable. It is heated up and will burn soon.
    New Friend:
  • 157 Answers
There is may be a problem with your power cable. You need to fix it properly.
Posted on Jul 24, 2013
SOURCE:
I got cryptic answer regarding the problem that the picture on the monitor on my camcroder GZ-HM400 is upside down.
There is a switch within the camera that controls the orientation of the LCD image. When the screen is flipped upside down, the switch is supposed to tell the camera to flip the image upside down as well. If this switch is damaged, the camcorder gets the wrong signal and the image will be displayed upside down. This can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 25, 2010 | JVC Video Cameras
Th e Viewfinder image flips upside down erratically. Meaning as I rotate the viewfinder it is suppose to flip upside down as it rotates towards the subject being shot. But lately it'; s started...
There is a switch in the LCD hinge mechanism that controls the image flip. It appears to be failing and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Sep 15, 2010 | Sony PMW-EX3 High Definition Camcorder
My Sceptre television picture is upside down, can you help me fix it? Also no matter what we program into the TV it keeps coming up " Program Locked" upside down of course any clue to my problem?
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
Mar 06, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Screen upside down
Holding down CTRL and ALT while pressing the DOWN ARROW flips the screen upside down.
To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW.
You can also try CTRL-SHIFT and then “r” … this works for some Dell configurations
This problem can also be solve in some PC using the below technique.
In Control Panel>Display>Settings tab>Advanced button, look for settings relating to display or screen position.
Newer video cards have the capability to flip the display 90 and 180 degrees for use with LCD screens that can be rotated.
If the problem still persist, Start you PC with F8 key press, select "Last known good configuration that works"
it will most probably solve the problem.
Jan 20, 2010 | ASUS Eee PC 1000H Laptop
Upside down monitor
CTRL - ALT - <up arrow> should fix you up.
Mar 06, 2009 | Dell E153FP 15" LCD Monitor
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Display is upside down
AN EASIEST WAY IS HOLD THE CTRL AND ALT KEYS,AND CLICK THE "UP" KEY
Jun 02, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Everything is flipped
in the video settings you will see an option that will flip it back to normal
good luck
Terry
Apr 01, 2008 | Dell E176FP 17" LCD Monitor
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
Dell ST2310 23 inch LCD Monitor Logo
59 people viewed this question
Clive
Clive
Alun Cox
