Question about Dell ST2310 23 inch LCD Monitor
Weird LCD Monitor ST2310
I bought a refurbished Dell ST2310 and after a month it started giving me dim display.. after keeping it on for 2 minutes it start acting like switching between 100% brightness to 20% brightness repeatedly with no uniform pattern.. i disassembled the lcd monitor and plugged the power cord in and placed the lcd up side down (not intentionally), it was working fine untill unless i flipped it back to its normal position.. so i found by repeating the process few times that my lcd is working absolutely fine upside down.. please tell me what the reason and is there any user replaceable part in it so i can get it fixed ? thanks, many regards, Basit Zia
  • Basit Zia Jul 23, 2013
    looks like this lcd monitor has some sort of accelerometer. because even if i turns it slowly it changes it behaviour and when i turn it up side down again slowly, the lcd then starts working fine..
SOURCE: Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Posted on Dec 26, 2008
mplacchetti
  • 3 Answers
SOURCE: LCD monitor no display - flashing power button
Hate to criticize and then not help out. I have this exact same problem with one of my E152 Dell Displays. I have read around and this whole line of displays seemed to have trouble. I found many issues like this and no solutions.
So, I like to tinker and tinker i did. I opened the case, removed the screen and went straight to the power supply board where I found two burned out capacitors.
RATED:
Value Voltage Diameter Height
1000uF 16v 10mm 16mm
Found a great source for replacement parts and instruction to replace the caps at BadCaps.net
Let you know how it goes.
Posted on Apr 29, 2009
SOURCE: Dell 17" Monitor - Won't display anything, power light flashes
Buy a new one! Thats all I can say babe!
Ha! i was at school searching you online and found this!
<3 Netty
Posted on Jun 01, 2009
  • 1684 Answers
SOURCE: Dell LCD Monor light keeps blinking green, screen
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 27, 2009
SOURCE: My Dell 1905FP LCD monitor Power light blink on startup
It's most likely a couple of the eletrolytic capacitors on the power supply board. This type of cap can go bad over time, and that would lead to the symptoms worsening over time like yours has. It's mostly likely a couple of 10V, 100uF caps in my experience. They should be easy to identify: they will be the ones with the top bulging upwards. Replace those and you should be good to go! If there aren't any bulging caps, just replace all the 100uf caps. (there should be no more than 5)
If you attempt this yourself though be carefull: any caps that haven't gone bad can hold a charge even when the monitor is powered off. Depending on the capacitor of the cap, accidentally contacting the leads on a charged cap can be anywhere from painfull to dangerous! A preventative measure is using an insulated handle screwdriver, short both leads of the cap together on the backside of the board to drain the cap.
Posted on Dec 07, 2009
In a dell e177fpf lcd monitor all the capasitors fuses diodes in power supply and inverter board are ok.but the back lights remains 2 seconds.
Hello...I recently opened up my Dell E173Fpf monitor because the screen went black, yet the power button was green. I thought it was a capacitor problem. But before doing anything I gave the board a thorough inspection, looking for anomalies. I observed a substance, (later identified as silicon) puddled around the power connections. I gently removed the semi rigid stuff and didn't touch the capacitors as I had originally planned. I partially reassembled the monitor for a test run and it worked again. (Being 9 years old, I don't know for how long...) Only thing I can think of is that a spill happened at the factory and over the years it gradually "melted" to puddle around the wires behind the power input. (Weird, but that seems to be what happened.)
Dec 05, 2014 | Dell 17" e177fpf lcd monitor black
Dell ST2310 goes blank
Change the settings to "always on" (both of the monitor and the computer).
Dec 08, 2013 | Dell ST2310 23 inch Monitor
My lcd works fine untill i flip upside down
There is may be a problem with your power cable. You need to fix it properly.
Jul 23, 2013 | Dell ST2310 23 inch LCD Monitor
I have a mac mini osx10.4 with a 512N syncmaster samsung monitor. The monitor worked fine for 2 years and up till the last month while I am on the computer the monitor will go black with a message saying...
samabbott, Toni, The very first thing to check is Samsung warranty.. If not valid you will need to check and see if Samsung has a cash+old unit swapout program for refurbished same model??? Will this 512N do same thing if connected to different pc? If so, then I would suspect the unit's power supply. Whenever strange or weird stuff starts to randomly take place with an LCD display, I would first check the "switch-mode-power-supply"! Have you tested the pc with different Known Good lcd unit? Try the above stuff and report back with a new comment. 12fixlouie
Nov 17, 2009 | Samsung SyncMaster 512N 15" Flat Panel LCD...
I want to attach my St2310 monitor to a support
There is a Bracket for sell on ebay the item nubeItem number: 200519763403
Item number: 200519763403The item number is: 200519763403
Oct 01, 2009 | Dell Computers & Internet
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
E172fpb monitor that turns on, but then goes dim
Your display have an inverter driver broken, So the back light can't turn on. Here is a website that shows this issue:
http://josepino.com/?howto-repair-dell
Feb 14, 2009 | Dell E173FP 17" LCD Monitor
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
Dell ST2310 23 inch LCD Monitor Logo
Alun Cox
