Question edited for a lot more clarity and for spelling.
Question moved from Super computers category.
Are you sure it it a refrigerator and a refrigerated AC unit?
Super General AC error code e5
"E5" - Fan Motor Problem: Occurs when the over current from the fan motor is detected. Solution: Verify Power (Voltage/Amps).
How do I fix P2 error in AC?
If the P2 or FL error code is displaying on the air conditioner, remove the drain port cap and tilt the air conditioner to the back so the water runs out of the drain outlet. If no water is draining out when the air conditioner is tilted to the back, the unit will require a repair service.
Dec 11, 2018
Error code E3 on a Super General air conditioner model SGSi188-i5 indicates a communication error between the indoor and outdoor units. This could be caused by a faulty control board or a wiring issue.
You may try resetting the air conditioner by turning off the power supply for a few minutes and then turning it back on to see if the error code disappears. If the error code persists, it is recommended to contact a professional technician to diagnose and fix the issue.
If have a mini split unit that gives an E4, E5, E6, F1, F2, F3 error code a few things can cause this problems. How To Clear an E4, E5, E6, F1, F2, F3 Error Codes on a Mini Split
Power off the unit and turn off the breaker or disconnect.
Wait 2-3 minutes and power the unit back on.
Any problem that is not fixed will likely come back.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need anything else air conditioning related don't be afraid to check us out our AC Repair and information online
https://play.google.com/store/apps/details?id=com.tekoia.sure.activities&medium=referrer=utm_source%3Dsure-app-settings%26utm_medium%3Dreferral%26utm_campaign%3Dshare-via-app use this app for super general ac
