Question about 3203 2way Security System
When armed, alarm will chirp 10 times every 1-2 minutes
Wrong section
Look them over & repost
Your in motor vehicles
Posted on Jul 24, 2013
My Hornet alarm doesn't chirp, activate, or go off anymore. I've tried to check the valet mode, but it doesn't do anything. The remote still locks and unlocks door's and it cranks.
My car alarm doesn't chirp all the time, but it still unlocks the ...
forums.anandtech.com > Social > Off Topic
AnandTech
Feb 3, 2003 - 11 posts - ‎7 authors
My car alarm doesn't chirp all the time, but it still unlocks the doors. ... Distributed Computing. ·, Security. ·, Social. ·, Off Topic ... The rest of the electrical systemseems fine. ... Just read the owners manual and find out to to re-enable the ... but like when I arm my alarm it arms but then it'll go off for no reason.
Alarm Troubleshooting Help Tips - Dr.Detail
www.drdetailshop.com/TROUBLE.html
When you try to start the car the alarm goes off.. It could be your battery. 3. Try to start no sound, nothing lights up, alarm doesn't work. It could be a loose battery ...
Viper Alarm won't chirp help!! - 12 Volt Forum : Car security ...
www.tintdude.com > ... > 12 Volt Forum : Car security / Convenience
Sep 11, 2006 - 7 posts
posted in 12 Volt Forum : Car security / Convenience: Hi I am new to this site ... Myproblem is when I lock it it won't chirp or roll my windows up ... If I hold the lock button the siren will go off,and if I press and hold the AUX my windows will go down. ... It won't chirp when activated or when I hold the arm button.Missing: hornet
How To program DEI Viper Python Avital Sidewinder Valet ...
? 3:34
https://www.youtube.com/watch?v=r01ntAXGxBw
Mar 10, 2011 - Uploaded by Lessco Electronics
hi I have the viper 7142v alarm system,tge problem is I only had one remote,I ordered a spare but ... My alarm only chirps when i am programming lock and unlock functions. it does not ... As soon as I connect car battery my alarm goes off. ... I obviously don't have a remote, and it doesn't have a valet switch.
Jan 06, 2016 | Vehicle Parts & Accessories
How to fix a hard wired smoke alarm that won't stop chirping
you don't say what kind of smoke alarm you have, or what kind of chirping, so i'm assuming it's a once per minute chirp which usually indicates low battery, but can also indicate that the unit has some other problem...if the unit is more than 10 years old you should replace the entire thing (per NFPA72, the national fire code, all smoke ALARMS must be replaced every 10 years)...if this is newer than 10 years, try replacing the 9 volt battery being careful to follow any instructions that may have come with the unit or may be printed on the back, top or sides...good luck.
Oct 16, 2015 | Home
When armed, alarm chirps 10 times every 1-2 minutes
Repost in proper place
You won't get answer under vehicles
Jul 23, 2013 | 3203 2way Security System
Why does my viper alarm suddenly start chirping?
Mine does that too (chirps 8 times), every 4 to 8 hours or so (seems to be random but persistent). The alarm was installed November 2014 and I just started noticing it in May 2015, possibly because I am now within earshot of where my car is parked?
Apr 28, 2012 | Viper Security and Remote Start System...
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm is on a 1996 f150 the alarm will not chirp the led on truck is solid it isnt blinking and it is a 5701 viper
Your alarm got put into valet mode some how
.It's easy to reverse out of it back to normal. First look for a small black push button under the dash somewhere. It's called a valet button. Here are the steps.
1. open door
2.turn key on then off
3.then within 10 seconds hit that valet button once(your alarm light should be off. Tell you arm it again. Then it will blink)
Hope this helps
Aug 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My remote says no antenna. can not arm alarm.
REPROGRAM YOUR REMOTES USING THIS PROCEDURE:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
Jul 06, 2010 | C3 RS6652W (NEW with 1 LCD Transmitters)...
Alarm is mal- functioning need to by pass alarm made by karr i think orinal equipment car starts sporatacly but have to play with remote to get it t o start help
It is simple just trace the wires - you will notice that installer will have teed in the wires – just cut off the T to the alarm - where you spot wires have been cut and attached with the alarm wires, just remove the alarm wires and rejoin the original wires and you won't face the alarm problem again.
A lot of owners coimment about Karr alarms and are so bad! Do yourself a favor and replace it (they comment like a personal opinnion).
I just got an accord and it came with a paper manual for the 2040. I had to reprogram the remotes though. Here is how Kar said to do it, you will have to fool around with it to figure out which buttons go to which channel, and I only had to press the button 3 times not on off to get it into the mode. So when it beeps once it meets its in channel 1, twice, channel 2:
* First, locate your valet switch. The valet switch is either going to be a small black push button, or a small silver toggle switch. The valet switch is either mounted on the plastic panel on the left side of the vehicle, near your left ankle as your sitting normally in the driver’s seat or directly behind the LED light.
·Turn your ignition key to the “on” position, or start the vehicle.
·Within 10 seconds
+ you have a silver toggle switch:
·Flip the switch “on” and “off” three times. (on-off-on-off-on-off) qIf you have a valet push button:
·Push the push button three times.
* The alarm system will chirp one time, letting you know that the alarm is in programming mode.
·Hold down the arm/disarm (center) button on the transmitter, until the alarm chirps again, confirming that the transmitter has been learned.
·Turn your ignition key off.
* The alarm will give one last chirp, letting you know the alarm has exited programming mode.
* The new transmitter is now programmed to the vehicle, and will arm and disarm the alarm system.
If you have problems programming the transmitter, please feel free to call at (949) 707-4210, or toll free at (800) 395-5277.
Here you can find your wiring diagram for Dodge Intrepid Car Alarm
Good luck.
Apr 20, 2010 | 1999 Dodge Intrepid
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
3203 2way Security System Logo
27 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
