Question about Cell Phones
I'm having this problem in my nokia e5 : My memory
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Posted on Aug 07, 2017
SOURCE: camera on stand by mode.failed operation of move file
I had same problem with same model – the applied solution is below
Just format the storage card & it should work!
Kiran Pawar
Posted on Apr 02, 2009
SOURCE: LG shine KE970 MP3 player wont play music from memory card
yes you can, just put the mp3 file on folder "Sound" on the external memory, it will be automaticly put  in your playlist mp3 player.
Posted on May 14, 2009
Achabacha
  • 113 Answers
SOURCE: music does not play on my CECT i9
Try Refresh List or check in your Music Settings if the Memory Card is selected or not.
Posted on Jun 06, 2009
SOURCE: i68 music player problems
i have the same problem than you. there is only one solution: the music must be in the folder "my music" and not in the memory card\audio ou received...
Posted on Dec 30, 2009
SOURCE: nokia phone c3...i have a
u mean "memory full delete some data?" i that's your problem, the only solution is to format your phone......
Posted on May 15, 2011
How do i delete unsuported files in my Nokia e5 phone memory
you can't delete it on phone if you have data cable connect it to pc then you will be able to delete these corrupt files
Jul 01, 2012 | Nokia E5 Cell Phone
Why my music player not played?
First of all check your Memory Card,it should be less than 1GB according to the direction given by NOKIA.If your memory card is more than 512mb,,,,music player might frequently corrupted due to the over usage of memory.So, if you want to recover you need to flash the phone....therefore contact mobile repairing shop or follow the instruction given below.But, if possible do not use a memory card of more than 512 mb coz this problem will occur again and again
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
Aug 29, 2011 | Nokia 3110 Cellular Phone
My nokia e5 is getting restart
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Aug 02, 2011 | Nokia E5 Cell Phone
I have Nokia mobile E5. My captured photos/videos are deleted automatically in 2-3 days. What to do.
If you have a memory card for your mobile phone,your data is saved on the memory card.And you can recover deleted photos and videos from the memory card with memory card recovery software.I had succeed to recover deleted photos from memory card of my phone with Asoftech Data Recovery.You can get it from http://www.asoftech.com/adr/
Jul 29, 2011 | Nokia E5 Cell Phone
I forgot my memory card password
Hello B,
To Remove the password of Nokia E5 Cell Phone memory card :
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
Jun 02, 2011 | Nokia E5 Cell Phone
My nokia E5-00 has problem that it gets switch off regularly after few minutes and if i browse internet
The phone must have hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
May 28, 2011 | Nokia E5 Cell Phone
Cell Phones Logo
168 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
