Question about Mitel Computers & Internet
Gateway error add gateway error using option 43:43
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
MY DESK TOP COMPUTER, FX4710-UB003A STOPPED PLAYING MY GAMES AND A CODE POPED UP 43, I ALSO HAVE LINES ON MY MONITOR, I THINK IT IS MY HARD DRIVE.
Lines on the monitor is a signal that the monitor might be bad or the video card is going bad.
Try another monitor on the computer. If you don't have one borrow one from a neighbor, friend, relative or co-worker. If the other monitor works without showing the lines, then your original monitor is bad. If the other monitors shows lines just like your original monitor then the video card is going bad.
When does this code 43 pop up? Does it give you any error message with the code?
I looked it up and i think it has to do with a usb device.
Check the links below and see if they help you.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/code-43-error-on-windows-7/be1bdcca-7864-47c8-b9e0-cbc65488ba22
May 04, 2012 | Gateway FX4710-UB003A Core 2 Quad Q9300...
What is error code 43 for AMC 5 on a mac?
Mac Error Code 43 occurs due to wrong OS Configuration or due to wrong installation. To Fix Mac Error Code 43, just read the easy steps are given below:
Easy Steps to Fix Mac Error Code 43
Step 1: Reset PRAM Settings
    ·First shut down your Mac computer.
    ·Meanwhile Mac is shutting down you need to prepare for pressing command+option+P+R keys all together.
    ·Now turn on your Mac and press command+option+P+R command before the screen with grey start-up appear.
    ·At this point of time hold all these keys until you hear a start-up sound for three times and then release all the keys. Step 2: Delete All Locked Files
    ·You need to navigate to Applications then open utilities and click on terminal.
    ·Now open the terminal and type chflags -R nouchg command on it.
    ·Now find at the bottom dock and double click on the Trash icon.
    ·Press command+A to select all the files in the trash folder.
    ·However, in case of you not able to find the terminal window, arrange finder window, so that you can see at least a part of terminal window.
    ·If you have done then press Return key on the terminal and empty the trash folder.
    After following these steps if you are unable to Fix Mac Error Code 43, then just dial our toll free Mac Technical Support Number 1-833-493-0111 and get instant help.
1 833 493 0111 How to Fix Mac Error Code 43 on Mac OS
Aug 19, 2010 | Avid Media Composer 3 Upgrade Version for...
Can you fix an internet explorer script error? Line:43 Char:12 Error Library not registered
yes, it can be fix, locate the toolbar that causes the problem and use the add/remove programs to uninstall it.
http://en.community.dell.com/forums/t/19316073.aspx
Jan 24, 2010 | Computers & Internet
Cannot synchronize my phone, showing error code 43
Code 43 Windows has stopped this device because it has reported problems. (Code 43) Recommended resolution
One of the drivers controlling the device notified the operating system that the device failed in some manner.
If you have already run the Troubleshooting Wizard, you might want to check the hardware documentation for more information about diagnosing the problem.
Try reinstalling the ActiveSync Software.
Dec 02, 2009 | HTC P3300 Smartphone
Computer - Intelchips 82945G - Error Code 43
When your computer loads, after you power it on, it gives you an option to go into the CMOS. You can disable integrated periferals there. If you don't know how, check your system documentation
May 10, 2009 | MSI Computers & Internet
Deleting
Error -43 is the common "File Not Found" error.  This can also mean a folder is not found. (A Google search for "macintosh error codes" returns a complete list from Apple at http://support.apple.com/kb/HT1618.)  I don't know why it would say this unless the files really don't exist.
Dragging an item to the Trash doesn't usually require a password unless you are not the owner of the item.  This can occur when copying items from another user's account, for example.
Try selecting all of the items that you want to delete, hold down the Option key, and choose Show Inspector from the File menu.  In the Sharing & Permissions area at the bottom of the Inspector window, verify that you have permission to delete the files.  If not, click the lock icon, type an administrator's username and password, then change the Privilege to Read & Write (you might have to use the + icon to add yourself to the list before changing anything).
Close the Inspector window and delete the items.  This should do the trick.
Feb 25, 2009 | Apple Mac 10.5.1 Desktop
Error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Mar 23, 2008 | Fisher Paykel Eco IWL16
Computers & Internet Logo
145 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
