Question about Pelonis FS10S1 Tower Fan
Tower fan not oscillate
Is there a reset button or something else to try before tossing it out?
  • Nancy Light Cook
    Nancy Light Cook Oct 06, 2014
    I have the same question. Anyone out there know if we can repair DIY?
Comfort zone tower fan won't oscillate
Remove bottom and check if gear is stripped or very dirty so can't turn.
Dec 14, 2013 | Comfort Zone 30 In Oscillating Tower Fan -...
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
I stupidly tried, in the wee hours half asleep, to force the fan to turn to a certain direction when the oscillation was turned off. Something broke and rattled around, and now the oscillation is...
Unfortunately, no - the manufacturer does not supply replacement parts. It is a throw-away item.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Seville Classics MSC10166 Tower Fan
FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
Aloha Breeze Tower Fan Will Not Oscillate
hi,
yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
good luck
J
Aug 05, 2008 | Tower Aloha Breeze Fan
How do you open up a BDTF101B Tower Fan?
first you have to remove the two plugs on top behind the buttons remove the two screws next you have to remove the base stand and their is one screw you have to remove then you can remove the front cover and you can get to the motor and fan.
May 29, 2008 | Black & Decker BDTF1010B Tower Fan
I have a Honeywell oscillating quiet cooling tower fan that was bought two years ago. Loved it, till yesterday it just stopped working. the oscillating feature still moves, but the fan does nothing. the...
Could be fixable but until someone determines the problem there is no way of knowing if it is fixable. Could be a broken wire between the selector switch and the motor or the motor itself could be bad.
When you are trying to operate it does the fan motor get warm or hot? Does the fan turn freely?
May 03, 2008 | Heating & Cooling
I am trying to fix an Oscillating Tower Fan.
Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have.
Sep 04, 2007 | Black & Decker BDTF1010B Tower Fan
Pelonis FS10S1 Tower Fan Logo
Top Pelonis Dryers Experts
Dan Webster
Dan Webster
Are you a Pelonis Dryer Expert? Answer questions, earn points and help others
