Question about Sony RM-V701 Remote Control
I want a code for AEK EVD198L - Sony RM-V701 Remote Control
    Top Expert:
  • Sony Master
  • 75,283 Answers
Check these codes. 1349 1423 1061. If you wish to get more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://remotesearch.blogspot.com/
Posted on Jul 24, 2013
My tv failed to starts ( I see only vertical stripes and have sound) after a few kicks on the back of the panel it is start normally
You either have a Dry Joint, (Bad solder connection) or a Plug thus has not been seated properly on one of the boards which is quite an easy process to repair. You have to remove the back panel and check ALL connectors on all the PC Boards until, by lightly moving the plug and wiring, you find the loose plug and then just press it in place until tightly seated. If not the problem, look for a bad solder joint on the Boards interconnecting wiring until you find the bad wire and re solder.
Jul 31, 2014 | LG 37LE4500.AEK 37le4500 37 Inch FuHd Led...
Why my 1996 golf from turn off while driving, it sparks but I won't start, need to wait 30 min and it will start with no problem but if it keep driving it it will do the same thing... please help me
which engine? see list , mind blowing, and what country>???
doing a 60k mile tuneup works, at least once a decade.
ever do the list of parts, spark and fuel , per operators guide?
that be first, 99% of bad running engines are that.
my guess , (weak based on only 1 fact) is has lost fueling
the ECU in the all cars 96 tries 10x to stop stalls.
the reasons are this: (top list)
1: lost 12vdc power ,see dash lamps or other lights go dead at stall>?
2: lost spark (tune up time?)
3: lost fueling, (try test fuel start now.
4: flooded, are the spark tips soaked in raw gasoline. (use wide open throttle cranking, does that work? this cuts fuel. (a secret mode)
5: ISC dead? (start car with 10% throttle) ok ISC is funky. clean it.
can you save the stall with fast right foot? (key fact here)
gen 3 engine list.
1.4 I4 40/44 kW (ABD/AEX/APQ)
1.6 I4 55 kW (ABU/AEA/AEE)
1.6 I4 74 kW (AEK/AFT/AKS)
1.8 I4 55 kW (AAM/ANN)
1.8 I4 66 kW (ABS/ADZ/ACC/ANP)
2.0 I4 85 kW (2E/ADY/AGG/AKR/ABA/AWG/AWF)
2.0 I4 16v 110 kW (ABF)
2.8 VR6 128 kW (AAA)
2.9 VR6 140 kW (ABV)
1.9 I4 D 47 kW (1Y)
1.9 I4 SDI 47 kW (AEY)
1.9 I4 TD 55 kW (AAZ)
1.9 I4 TDI 66 kW (1Z/ALE/AHU)
1.9 I4 TDI 81 kW (AFN/AVG)
Jul 10, 2014 | Cars & Trucks
My 2001 vw cabrio is overheating. when we checked the thermostat is working and there is coolant going through the hoses to the engine. There is a loud knocking that is coming from the the area around the...
Gas to Diesel, turbo or not? 14 engines
1.9 I4 D 47 kW (1Y)
which engine does yours have?
on machines, all, fix noise first. noise means , i'm going to blow up
or die, or fly apart, or cause you damage or the engine collateral damage, (damage can be unlimited)
my wildest guess, I'm blind see and deaf, is the water pump is getting ready to blow up. Self destruction as all do, if ran to infinity.
the fan must turn on at all overheats or it is bad, or its trip sensor is bad or its own relay is bad or the wires, end to end this path are bad.
some cars have 3 fans, 2 on rad rear and 1 on AC,
my comment is RAD FAN(s).
asking for help to blind people on the net./ why not get hands on help, you in YUKON? ask a neighbor, to look or friend or son or some with machine experience,
doing it wrong can be very expensive. why risk that.?
or get hurt.
see here for vast overheating reasons, and works for all cars.
(no electric pumps)
http://www.fixkick.com/overheating.html
on newer cars the PCM controls all fans, under ALL conditions via RELAYs.
the varies by year, model , country and engine options.
what country is this car.?
cabrio
or
Cabriolet (missing let?)
cabribe? mexican?
a gen 3:!
Third generation (A3/Typ 1H, 1993-2001)
the Mk3 Golf Cabrio received a Mk4-style facelift for the late 1999 model and was continued until 2002.
here is the list, what engine?
http://en.wikipedia.org/wiki/Volkswagen_Golf_Mk3
Oct 20, 2013 | Volkswagen Cars & Trucks
On my Cdj1000MK3 only the jog wheel lights come on but nothing on the display screen that shows the tune name,number,BPM etc. It still works fine but obviously would like it sorted out. Cheers
The CDJ1000mk3 has some yellow fuses that look like this:
http://artaudioparts.com/product/aek7023/
Open it up and use a multimeter to check if any of these fuses is blown. A blown yellow fuse could be your problem. I do not remember right now which fuse is responsible for the screen.
Check the service manual and find the part number, it begins with "AEK".
If you find it drop us a message here:
http://artaudioparts.com/contact-us/
so that we list the part online, if we have not already upload it.
www.artaudioparts.com
Aug 07, 2013 | Pioneer CDJ-1000 CD Player
I don't know why stop my ipod
Greetings Aek Smarth,
Your ipod has probably overheated. Here is what you should do:
  1. Turn on your ipod and let it play until it dies.
  2. Plug in your ipod and fully recharge it.
If your ipod is unable to be turned on:
  1. Plug it in and charge it for over a day.
  2. Attempt to turn it on after this day.
After having it plugged in for a day, it should reset itself and be like normal. If it does not reset itself, than your out of luck. Thank you for using FixYa! =)
Nov 18, 2010 | Apple iPod MA446LL/A MP3 Player
Hi I need PHILIPS P568 IMEI 351265412565412 unlocking codes.... please help me.
Codes for imei 351265412565412, model Philips P568 Unlocking codes: Code for NCKKN is : **00012*39094694# Code for NSCKN is : **00022*35077294# Code for SPCKS is : **00032*36089094# Code for CKCCK is : **00042*37037294# Code for PCKKP is : **00052*33054694# Code for XXXXX is : **00062*37035294# Code for XXXXX is : **00072*33775294#
Repair codes: Code for NCKKN is : **00013*43714762# Code for NSCKN is : **00023*43070742# Code for SPCKS is : **00033*43251752# Code for CKCCK is : **00043*43072702# Code for PCKKP is : **00053*43718722# Code for XXXXX is : **00063*43872702# Code for XXXXX is : **00073*43878442#
New Algo Codes Unlocking codes: Code for NCKKN is : **00012*7563374371217567# Code for NSCKN is : **00022*7161634379412367# Code for SPCKS is : **00032*7262814378202967# Code for CKCCK is : **00042*7367634371472367# Code for PCKKP is : **00052*7969374375277567# Code for XXXXX is : **00062*7367434371470367# Code for XXXXX is : **00072*7931434377110367#
Repair codes: Code for NCKKN is : **00013*2159969789537257# Code for NSCKN is : **00023*2185567789015457# Code for SPCKS is : **00033*2103668789074247# Code for CKCCK is : **00043*2185763789017417# Code for PCKKP is : **00053*2159365789531217# Code for XXXXX is : **00063*2165763789817417# Code for XXXXX is : **00073*2165337789813157#
May 17, 2010 | Belkin Cameras
QUIERO SABER CUAL ES EL CODIGO PARA UNA TELEVISION SHARP SP
aver si te ayuda esto
Code 000 for RCA TV Code 003 for RCA TV Code 004 for RCA TV Code 005 for RCA TV Code 006 for RCA TV Code 007 for RCA TV Code 019 for RCA TV Code 054 for RCA TV Code 055 for RCA TV Code 082 for RCA TV Code 096 for RCA TV Code 098 for RCA TV Code 099 for RCA TV Code 100 for RCA TV Code 101 for RCA TV Code 102 for RCA TV Code 103 for RCA TV Code 129 for RCA TV Code 179 for RCA TV Code 181 for RCA TV Code 188 for RCA TV Code 190 for RCA TV Code 196 for RCA TV Code 202 for RCA TV Code 203 for RCA TV Code 212 for RCA TV Code 215 for RCA TV Code 233 for RCA TV Code 281 for RCA TV Code 352 for RCA TV
estos son los codigos
May 05, 2010 | RCA RCU600M Remote Control
How to get free GTA SanAndreas CHEAT CODES?
here are all the cheat codes
Adrenaline Mode
Cheat code: MUNASEF Aggressive Drivers
Cheat code: YLTEICZ All Cars Explode
Cheat code: allcarsgoboom All Cars Have Nitro
Cheat code: COXEFGU or SPEEDFREAK All Green Lights
Cheat code: ZEIIVG Always Midnight
Cheat code: NIGHTPROWLER or XJVSNAJ Beach Party
Cheat code: CIKGCGX Black Traffic
Cheat code: IOWDLAC Blow Up All Cars
Cheat code: CPKTNWT Boats Fly
Cheat code: AFSNMSMW or FLYINGFISH Cars Float Away When Hit
Cheat code: BSXSGGC or BUBBLECARS Cars Fly
Cheat code: RIPAZHA Chaos Mode
Cheat code: STATEOFEMERGENCY Clear Wanted Level
Cheat code: ASNAEB Country Vehicles and Peds, Get Born 2 Truck Outfit
Cheat code: BMTPWHR Elvis is Everywhere
Cheat code: ASBHGRB or BLUESUEDESHOES Everyone is Armed
Cheat code: FOOOXFT Faster Clock
Cheat code: YSOHNUL Faster Gameplay
Cheat code: PPGWJHT or SPEEDITUP Fat
Cheat code: BTCDBCB Foggy Weather
Cheat code: CFVFGMJ Full Weapon Aiming While Driving
Cheat code: OUIQDMW Funhouse Theme
Cheat code: CRAZYTOWN or PRIEBJ Gang Members Everywhere
Cheat code: MROEMZH or ONLYHOMIESALLOWED Gangs Control the Streets
Cheat code: BIFBUZZ or MROEMZH Have a Bounty on Your Head
Cheat code: BAGOWPG Have Jetpack
Cheat code: ROCKETMAN or YECGAA Have Parachute
Cheat code: AIYPWZQP Health, Armor, $250k
Cheat code: HESOYAM Hitman In All Weapon Stats
Cheat code: NCSGDAG or PROFESSIONALKILLER Huge Bunny Hop
Cheat code: CJPHONEHOME or JHJOECW Increase Wanted Level Two Stars
Cheat code: OSRBLHH Infinite Ammo, No Reload
Cheat code: FULLCLIP or WANRLTW Infinite Health, Except for Explosions and Falls
Cheat code: CAINEMVHZC Infinite Oxygen
Cheat code: CVWKXAM Invisible Car
Cheat code: WHEELSONLYPLEASE or XICWMD Large Health Boost
Cheat code: BAGUVIX Max All Vehicle Skill Stats
Cheat code: NATURALTALENT Max Muscle
Cheat code: BUFFMEUP or JYSDSOD Max Respect
Cheat code: OGXSDAG or WORSHIPME Max *** Appeal
Cheat code: EHIBXQS or HELLOLADIES Mega Jump
Cheat code: KANGAROO or LFGMHAL Mega Punch
Cheat code: IAVENJQ or STINGLIKEABEE Never Get Hungry
Cheat code: AEDUWNV Never Wanted
Cheat code: AEZAKMI or IFIRSTDOZ Ninja Theme
Cheat code: AFPHULTL or NINJATOWN No Wanted Level
Cheat code: TESTEDUCATIONALSKILLS Orange Sky 21:00
Cheat code: OFVIAC Overcast Weather
Cheat code: ALNSFMZO Peds Attack Each Other, Get Golf Club
Cheat code: AJLOJYQY Peds Attack You With Weapons, Rocket Launcher
Cheat code: BGLUAWML Perfect Handling
Cheat code: PGGOMOY or STICKLIKEGLUE Pink Traffic
Cheat code: LLQPFBN Rainy Weather
Cheat code: AUIFRVQS Recruit Anyone - 9mm
Cheat code: SJMAHPE Recruit Anyone - Rockets
Cheat code: ROCKETMAYHEM or ZSOXFSQ Reduced Traffic
Cheat code: GHOSTTOWN or THGLOJ Riot Mode
Cheat code: IOJUFZN Sandstorm
Cheat code: CWJXUOC Six Star Wanted Level
Cheat code: BRINGITON or LJSPQK Skinny
Cheat code: KVGYZQK Slower Gameplay
Cheat code: LIYOAAY or SLOWITDOWN **** Magnet
Cheat code: BEKKNQV Smash n' Boom
Cheat code: JCNRUAD Spawn Bloodring Banger
Cheat code: CQZIJMB Spawn Caddy
Cheat code: RZHSUEW Spawn Dozer
Cheat code: EEGCYXT Spawn Dozer
Cheat code: ITSALLBULL Spawn Hunter
Cheat code: OHDUDE or OHDUDE Spawn Hydra
Cheat code: JUMPJET or JUMPJET Spawn Monster
Cheat code: AGBDLCID or MONSTERMASH Spawn Quad
Cheat code: AKJJYGLC or FOURWHEELFUN Spawn Racecar
Cheat code: PDNEJOH or VPJTQWV or VROCKPOKEY Spawn Rancher
Cheat code: JQNTDMH Spawn Rhino
Cheat code: AIWPRTON Spawn Romero
Cheat code: AQTBCODX or WHERESTHEFUNERAL Spawn Stretch
Cheat code: CELEBRITYSTATUS or KRIJEBR Spawn Stunt Plane
Cheat code: FLYINGTOSTUNT or URKQSRK Spawn Tanker Truck
Cheat code: AMOMHRER Spawn Trashmaster
Cheat code: TRUEGRIME or UBHYZHQ Spawn Vortex Hovercraft
Cheat code: KGGGDKP Suicide
Cheat code: GOODBYECRUELWORLD or SZCMAWO Sunny Weather
Cheat code: AFZLLQLL or PLEASANTLYWARM Taxis Have Nitrous, L3 Bunny Hop
Cheat code: VKYPQCF Thunderstorm
Cheat code: MGHXYRM or SCOTTISHSUMMER Traffic is Cheap Cars
Cheat code: BGKGTJH or EVERYONEISPOOR Traffic is Country Vehicles
Cheat code: FVTMNBZ Traffic is Fast Cars
Cheat code: EVERYONEISRICH or GUSNHDE Very Sunny Weather
Cheat code: ICIKPYH or TOODAMNHOT Weapon Set 1, Thug's Tools
Cheat code: LXGIWYL Weapon Set 2, Professional Tools
Cheat code: KJKSZPJ or PROFESSIONALSKIT Weapon Set 3, Nutter Tools
Cheat code: UZUMYMW
May 02, 2010 | Rockstar Games Grand Theft Auto: San...
Gas burner will not completely lite
Call GE answer center 1-800-626-2000 aek for tech help. Have you Model # off your data plate ready.
May 09, 2009 | GE 30 in. JGP337 Gas Cooktop
Sony RM-V701 Remote Control Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
