Question about Sharp AR-5316 Advanced Digital Imager Copier
START PROBLEM When i start the copier the number 2 and the letter U are flashing on the screen and the copier dosnt oprate please how can i solve it.
    Problem Solver:
  • 6 Answers
U2 Counter sum check error When the counter check sum value stored in the EEPROM is abnormal
Enter sequence...clear, interrupt, 0, interrupt. The copier will go off. While off enter 16 and Start. Your copier will come back on. press Clear All.
may need a new cartridge as chip may be broken if this does not work
Posted on Dec 04, 2007
Enter this sequence...clear, interrupt, 0, interrupt. The copier will go off. While off enter 16 and Start. Your copier will come back on. If it doesn't come back on, enter Clear All.
Posted on Sep 26, 2007
PLEAZ OPEN THE FRONT DOOR,AND RE INSTALL THE TONER CARTRIDGE,IF NOT DO THIS PROGRAME,HASH,INTERRUPT,C,INTERRUPT, THEN PANEL WIL B OFF PRESS 16 THEN COPY KEY IT WILL FINISH IF LIT AGAIN CHANGE TONER CARTRIDGE THANKS MUHAMMAD TARIQ FROM PAKISTA TELEPHONE 0092 334 6036320
Posted on Sep 08, 2007
2 Suggested Answers
SOURCE:
checkitright
  • 1362 Answers
SOURCE: Private
look at this link under error codes, look for copiers- sharp
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Nov 15, 2007
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Car dosnt start
What was the code the mechanic cleared?
Mar 31, 2014 | 2002 Honda Civic
Can you advise please
reset the machine make this: God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 28, 2013 | Precor 935 Premium Series Treadmill
My nokia 1100,the is a display of contact service on because of that i can't use it please help me to slove this problem
My Dear Brother:
flash new software install in the phone problem will solved quickly
Contact service problem will Quickly Solved
2:OR:
contact service center And Hilp the Service Oprator
Thanks
Aug 15, 2010 | Nokia 1100
I have somehow managed to come accross a screen on my samsung genio touch (o2) titled PUK it is asking me for a 4 to 8 digit number and I cant find anything in my handbooks about it please can you help me
My Dear:
You Go To Sim Office Or You contact Service Sim Office And Get The Puk code From Office Oprater
Enter The Puk code And Yes So Puk code Open
OR:call Service center and Hilp the Service Oprater For Puk code
Puk code Problem will Solved
Aug 13, 2010 | Cell Phones
My jeep 2002 cherokee dosnt start right away , it takes about 2-3 times till it starts
have about three customers with the same problem and i havent managed to solve it as yet,so if find the answer please let me know .
May 16, 2010 | 2002 Jeep Grand Cherokee
The letter L and then the number 1 appears when we turn on Help
My my how does this work? You will charge me to solve the problem but if I solve it myself you wish me to tell you how. Do I charge you for my solution then ? It makes no sense to me.
I solved it by the way but I'll keep it to myself thanks.
Aug 31, 2009 | Toshiba e-Studio 161 Copier Copier
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
F2
Hi i think the problem code for f2 problem is to enter this code pressing * interrupt CA interrupt then the light will go of then you enter 80 then press copy and 1 copy.
Aug 09, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
73 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
