Question about Garden
Simplicity mower model 1694624
The mower shuts down electric circuits as soon as you turn the key on, no instruments nothing. When I pull the plug on the voltage regulator, I think that's what it is mounted on the side on the engine. The plug has 2 white wires with more coming out of the regulator. With plug together the solenoid clicks and the circuits go dead. When it runs with plug pulled apart something smells hot. I can't tell if it's a belt smell or an electrical smell. What do these 2 white wires go to? Any help would be appreciated.Jon
SOURCE: Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Posted on Oct 04, 2008
  • 127 Answers
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Posted on Jun 30, 2009
  • 66 Answers
SOURCE: i have a chraftsmen rideing mower model number 917
It has the ammeter for the charging system
Posted on May 31, 2010
  • 51 Answers
SOURCE: I have had an electrical problem with this mower
soliniod should have two small terminals one should get power when turn key to start position the other runs through ground curcuit which runs through break and pto switch most tractors wont start with out break switch working properly i would start with that first the i would go to pto switch. hope this helps
Posted on Aug 01, 2010
  • 6468 Answers
SOURCE: smells like burning rubber
sounds like a bad bearing take the belt off and see what pulley is hard to turn look for the one with dark marks on it from the belt
Posted on May 14, 2012
What year is my simplicity 50 inch riding mower with bagger. Model # 1694624 Serial # 00641
hi byron.
i can not find your model number.but try this link and scroll down the page might help you out.
What year is my simplicity 50 inch riding mower with bagger Google Search
Nov 02, 2017 | Garden
Simplicity Regent Starting Problem
The wrong seat switch was installed. There are black ones and gray ones. I believe you need the gray one for open circuits.
Aug 10, 2012 | Simplicity Regent 19.5/38
Blades stopped can't restart now engine won't turn over
Check battery voltage should be 12v or above. Battery could have gone bad or charging system bad. Voltage draw of electric clutch pulled battery down.
Sep 25, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Describe your troubleshooting guide for simplicity yard tractor Problem After releasing the brake the motor stalls.
Could be one of two problems.
First if the motor is pulled down to a stall when the brake is released I would check the tranny drive. Check and make sure belt is on all pulleys and not wedged between pulley and frame or case, make sure all pulleys turn freely and if unit has sat for a long time make sure belt is not rusted into pulleys. Finding the belt wedged or a frozen pulley should resolve the problem.
Second, if the motor shuts off as if the key was turned off then it may be an electrical problem. I am not sure what year simplicity we are discussing. Earlier models did not have all the safety features. I would start by checking safety switches and by starting at the rider presence switch ( on the seat).
Dec 07, 2009 | Briggs & Stratton Garden
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Won't start. Runs well when it does start.
the solinoid for the starter motor needs replacing
Jul 07, 2009 | Garden
Craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
