Question about Pelonis FS10S1 Tower Fan
Pelonis Tower fan quit working
Is there a reset button or anything else to try before tossing it out?
Pelonis HC-0114T Ceramic Heater parts
I worked in maintenance for several years, and often found hard to find parts at Grainger.com. Sometimes they can be pricey. Here's a link to there fan section. Fan Blades and Propellers
Feb 08, 2014 | Pelonis Heating & Cooling
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
How do I open the shell tower to clean the inside? SMC (Shell Electric Co. Model # TWS5
Here is some useful information for your product (as I had the same question today). The first link is to the official product page. The second link is to the PDF Form of that product's Manual. The third page is to a WikiAnswers tutorial of how to take it apart and clean it.
Sep 07, 2010 | Heating & Cooling
Honeywell HCM-300T QuietCare 3-Gal UV Tower Humidifier Fan/Motor seems quite noisy and occasionally squeeky. Is this normal?
no, it will be needing to be opened up to check if anything is interferring with fan operation I.E. broken fan, motor bearings, anything touching fan
Jan 31, 2010 | Heating & Cooling
Pelonis tower heater hc-0116 doesn't stay on for any length of time. Also, the oscillation is not working. What should I do?
these type of appliances are made very fragile the slightest jar could cause this. It is most likely the tip safty switch or thermal protection switch. you can not access either from outside the unit. I wouldn't suggest taking it apart. the part will be hard to get and cost too much. just get rid of it and get a new one.
Jun 07, 2009 | Pelonis FS10S1 Tower Fan
How do i clean this product
I use an artificial feather duster available at most disount stores.
Apr 27, 2009 | Pelonis FS10S1 Tower Fan
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
My tower won't turn on. I checked and it is plugeged in to a working outlet... the screen light is on and even one light on the tower is on -- but when I press the on button NOTHING happens.
hi ,
you can try this solution
unplug all cables , powerflee the system by pressing the start button for 30 sec , release it then replugg all the cables and check wheather it is working or not , secondly check wheather the powers supply fan on the back of tower is working or not, still it doesnt work turn off the tower and unplugg the tower and then openthe tower , check all cables and reset the RAM on the mother board ...you can try this basic troubleshooting , it will help u... waiting for response
May 20, 2008 | Computers & Internet
Pelonis FS10S1 Tower Fan Logo
Top Pelonis Dryers Experts
Dan Webster
Dan Webster
Are you a Pelonis Dryer Expert? Answer questions, earn points and help others
