Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Spark plug gap - Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
  • Poulan Master
  • 2,239 Answers
The spark plug gap should be set to 0.5mm
Posted on Jul 23, 2013
NEED SPARK PLUG GAP FOR 9BSXS 190-1VH
The gap is .040 and is pretty much a standard gap.
May 17, 2017 | Cars & Trucks
What is the spark plug gap for the above car which is 4 cylinder. thanks
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
Feb 04, 2016 | 1988 Oldsmobile Cutlass Ciera
Spark plug gap 96 gov safari ACDelco platinum 41-942
Spark Plug Gap - AutoZone
www.autozone.com/.../specificationsMain.jsp?...Spark+Plug+G...
AutoZone2004 Mercury Grand Marquis 4.6L SFI 8cyl ' Specifications ' Spark Plug Gap.
AstroSafari.com • Spark plug gap size?
www.astrosafari.com/viewtopic.php?f=43&t=81409
Jul 27, 2015 - You're doing a '96? I think EARLIER 2nd Gen 4.3's used a .045" gap ; I believe it changed in 2000 or 2001 but don't quote me on that. All i'm ...Missing: gov
AstroSafariVans.com • View topic - spark plug gap question
astrosafarivans.org > ... > ENGINES GENERAL/PERFORMANCE
Nov 28, 2012 - 15 posts - ‎4 authors
My question is do I gap the spark plugs per 89 4.3 specs or do I use the 95 .... The vortec heads for a V8 chevy are 1996 and up however there ...Missing: gov
What is the proper sparkplug gap? - CarGurus
www.cargurus.com > Questions > GMC > Jimmy
CarGurusMar 16, 2013 - My Haynes manual and various places I've seen online say the gap is .045 inches ... spark plug gap for 1992 4.3 160 HP? ... Used GMC Safari".Missing: gov
[PDF]2000 GMC Safari Owners Manual - GM Extended Warranty
www.vadengmpp.com/owners-manual/gmc/2000-GMC-Safari.pdf
Jan 27, 2016 | Cars & Trucks
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Dec 15, 2015 | Cars & Trucks
What is the gap for spark plugs for fiat punto grande 1400
If it's an 8 valve engine and not the 16 valve:
Bosch Spark plugs have a gap of 0.8mm
NGK spark plugs need a gap of 0.9mm
16 Valve engines have a 0.9mm gap on each type of spark plug.
Mar 05, 2015 | Spark Plugs BR4HS Plug 10/BX #3322
A gap tool is what you use to set the gap on your spark plugs...The gap is the tiny space on your spark plug that allows the plug to fire the engine. When you buy the spark plugs at the auto parts, the spark plugs come pre gapped for your specific engine. I usually check them to make sure.
Aug 03, 2014 | 2003 Suzuki VZ 800 Marauder
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Whet is spark plug gap
Spark plug gap refers to the amount of separation between the center electrode of the plug and the bent tang at the bottom of the plug. Too small a gap and you get a weak spark. Too wide a gap and the plug may not fire every time. Most bikes today have CDI (Capacitor Discharge Ignition ). CDI produces a strong spark and works best with a gap of .35 to .45.
May 08, 2010 | 2002 Suzuki GZ 125 Marauder
Spark plug gap
Notice: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage.
Gap the spark plug, using round wire type spark plug gap gage.
Gap Adjust the spark plug gap to 1.14 mm (0.045 in).
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
If your going to use Platnum plugs, DO NOT GAP them. Just check the gap and if there not the right gap, ask for new one's with the right gap.
The metal on the PLatnum plugs, are harder and my break apart in the cylinder .
Good luck and hope this helps
May 02, 2009 | Pontiac Sunfire Cars & Trucks
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
