Question about Dryers
I have a GE electric dryer and it heats up but stops after 20 minutes. There's no cool down time I just have to reset the controls and turns right back on. Plz help thx
    Problem Solver:
  • 13 Answers
You must haved set it for 20 mln.
Posted on Jul 24, 2013
  • Scott Andersen Jul 24, 2013
    Is that supposed to be a joke? Very funny!!! Can I get someone to help me with some real skills. Thx
  • 1073 Answers
SOURCE: whirlpool electric dryer will not heat
check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
Posted on Apr 12, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
dragonsthatk
  • 547 Answers
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
  • 83 Answers
SOURCE: Electric Dryer remains running without heat and trips breaker
Your dryer needs a new timer.
Posted on Sep 10, 2009
ftw1952
  • 10319 Answers
SOURCE: GE profile harmony dryer has power, drum turns,
check out the ignition spark ignitor
that makes the burner to heat up
Posted on Mar 12, 2010
Dryer stops after about 20 min then you can restart after 5 min cool down time
The motor is overheating and needs to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | GE DBXR463EDWW Electric Dryer
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
    heatman101
    Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
    GE elect dryer is cutting off prematurely after 10-20 minutes no matter what setting on timer we use. I'm guessing it's a heat sensor but i don't know where it's located. Model #...
    It could be a high limit overload, but the cause may be a blocked air vent. You can remove the dryer vent in the back and see if the problem stops, this will tell you if the vent is blocked or not. Ryan
    Jun 02, 2011 | General Electric Dryers
    Ok got a GE DVL223EB1WW Insufficent Heat
    Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
    Nov 19, 2009 | GE DVL223EBWW Electric Dryer
    After 20 minutes my whirlpool LGR3624EQ0 dryer
    Your motor is bad on this unit or your saftey t-stat is stopping so it won't over heat. Look at the t-stat first. Hope this helps!
    Aug 18, 2009 | Dryers
    DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
    you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
    PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
    Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
    Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
    The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
    May 07, 2009 | GE DVL223EBWW Electric Dryer
    Shutting off every 20 minutes
    Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
    Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
    Dryers Logo
    Top Dryers Experts
