Question about Polycom VoiceStation 100
Polycom voicestation 100 no dial tone
I have at my office a polycom voicestation 100. It was working up until about 3 months ago. Then it suddenly quit getting a dial tone and stopped working all together. So I got a new unit and power supply. Now the system will power up but I am not getting a dial tone. I used the cables that were plugged into the first system and have tried 2 different phone lines. Any thoughts?
SOURCE: polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Posted on Dec 03, 2008
SOURCE: polycom 2201-03309-001
The older Polycom SoundStations have power supplies that allow either anaog or digital signals. The phones themselves will work on either.
If your office phone systems are different, or if the extension it was originally plugged into was configured for analog and you are now plugging into digital would explain the problem.
Paul
Edge Telecom
paul@edgetele.com
Posted on Feb 16, 2009
SOURCE: Polycom Sound station - help it won't work!
This modelo has a separeted wire to the wall telephone jack ? If it is the case, once I had a problem like your and was the plug in the end the wire, I just cut out 3 ou 4 inches in the wire and clip another new plug and it was fine. These plug its a regular analog telephone pluf easily found in a eletronil part shop. I hope I had help in anyway.
Posted on Sep 12, 2009
  • 146 Answers
SOURCE: I had two SoundstationEX phones
yes do a full reset and reprogram for new phone number and all settings when you move phones
Posted on Mar 21, 2011
  • 125 Answers
SOURCE: What are possible reasons that the conference phone is not getting power?
If you know anyone that can test the power supply with a digital meter, you can check if the power supply works or not. the power control board on the voicestation might have blown. and If that is the case I wouldnt recommending fixing it. Getting a refurbished or used with maybe 3 months to 1 year warranty isnt that expensive on these systems. getting it fix might cost you about the same. But checking if the power supply is working or not would be the first thing you want to do. If that works. looking for a power supply is pretty easy.
Posted on Mar 23, 2012
Polycom voicestation 300
are you sure this feature is not blocked on your line? check with another phone connected to the same socket if you can dial the same numbers
Jul 30, 2014 | Polycom Lands Phones
Feb 27, 2012 | Polycom VoiceStation 300 Conference Phone
How do you conference in 2 separate #s? We tried: 1. Dial the 1st # 2. Press flash 3. Dial the 2nd # And how do you connect them on 1 call? Thank you!
This will depend upon whether your Polycom is connected to a PBX system or using a public landline. If using the Polycom through a PBX you may need to consult the system admin as you will often need to enter a 'conference code' before you dial the second party ie.
1. Dial the first party and ask them to hold
2. Press the Flash key
3. Dial the conference code for your system ie. #46
4. Dial the next party and ask them to hold
5. Press the Flash key twice and all parties are joined.
If you are using a public landline (ie. home phone line) then you will be limited to the conference services that your phone company provide and these are usually also accessed via a code. There are also conferencing services that for a fee you can dial into and follow the prompts to austomatically arrange your conference call.
May 17, 2011 | Polycom VoiceStation 300 Conference Phone
How do I receive 3 calls at the same time on a Polycom Voicestation 300 ? (conference style)
you cant
you can only call out to multiple people not receive multiples
try using a conferencing bridge so all people can call into one number and be connected that way
Feb 25, 2011 | Polycom VoiceStation 300 Voice...
How do you make a conference call on the Voicestation 100 polycom phone?
Press the speaker or ON button, then dial and wait for an answer.
Aug 12, 2010 | Polycom VoiceStation 100
I set up the polycom as instructed... I even confirmed with my helpdesk that the line is analog. When i turn the unit on I get a high pitched buzzing sort of sound... no dial tone? I also cannot dial in...
Try to plug a cheap analog phone into the same line instead of the voicestation to verify that it is indeed analog. It sounds as if you connected the phone to a specialty PBX line or similar. There are analog PBX that only work with their own phones. You can also try to connect the phone at home and see if it works on your analog line at home.
Aug 05, 2010 | Polycom VoiceStation 300 (220017910001)...
How do I conference call on a Polycom Voicestation 400?
Conference call is not a feature of the phone, but a feature of the telephone system in the company. Usually you press a sequence of keys like flash #02 to trigger this function in the phone system. If your company phone system does not offer the feature then you have to use an external conference call provider.
Jun 17, 2009 | Polycom VoiceStation 300 (220017910001)...
Polycom soundstation Ex - no dial tone
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
Polycom VoiceStation 100 Logo
130 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
