Question about Aiwa PX-E860 Turntable
Speed seems a little slow on 33s. How can I fix this?
  • 67 Answers
If the problem is encountered on both speeds, 45 & 33, then there is a high chance that you are in need of a belt replacement.
Here is a general guide on how to replace a turntable belt.
You can also use it to check the belt status.
Posted on Feb 12, 2014
My Optimus LAB 1100 is playing 45s ok but the 33s sound like the chipmunks
the turntable speed is incorrect
adjust with the speed control setting
many quality turn tables have bar codes around the outside edge and when viewed under a light those bars appear to be stationary when the correct table speed is set
It is a strobe affect in time with the frequency of the light
Dec 06, 2015 | Audio Players & Recorders
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
Mar 24, 2014 | Technics SL-BD20D Turntable
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
THE SPEED SEEMS TO BE A LITTLE SLOW
On most turn tables there is a knob or a lever to adjust rotational speed. If it does not seem to have one then the motor is most likely out of sync and would need to be manually adjusted.
Mar 13, 2011 | Audio Players & Recorders
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
a
Sep 22, 2009 | Dryers
My audio-technica PL50 plays 45s at the wrong speed.
believe it or not not it probably doesn`t even play your lp`s at the right speed? Its probably because your drive belt has actually stretched? rubber belts do wear and maybe seek out a replacement drive belt?
try this company?
mailto:info@needledoctor.com
May 19, 2009 | Audio Technica AT-PL50 Turntable
36e93 bryant furnace inop
CHECK THE PRIMARY CONTROL TO SEE IF IT IS LOCKED OUT. IF THE RED BUTTON HAS POPPED UP THEN PRESS IT ONCE TO START, IF IT DOESN'T RUN THEN CALL A TECHNICIAN. ALSO CHECK THE SIDE OF THE MOTOR TO SEE IF IT HAS GONE ON THERMAL OVERLOAD(LITTLE RED BUTTON). RESET IT AND THEN PRESS PRIMARY CONTROL BUTTON. IF MOTOR BUTTON HAS POPPED OUT THEN REPLACE MOTOR. COULD ALSO BE A BREAKER. GOOD LUCK THANKS FOR AN HONEST RATING AND FOR USING FIX-YA.
Nov 09, 2008 | Bryant 462AJC021BA Air Conditioner
Aiwa PX-E860 Turntable Logo
199 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
