Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Convergence I am having green outline is there a way to fix this myself or will i have to have it serviced
  • Jazy Sep 03, 2007
    what can i do to fix the green and red outline in the picture
    Problem Solver:
  • 8 Answers
THE HITACHI 50V500 DOES NOT HAVE A CONVERGENCE CIRCUIT IT USES A LAMP AND LIGHT ENGINE
Posted on Sep 02, 2007
I have a PHILLIPS scrren HDTV MODEL #51PP9100D/37 and it hs green and red outline on picture. Can you tell me what could be wrong? Can this be fixed? Didn't know if it is something I can do myself or...
Its a convergence problem. The three color guns have drifted and it shows on the edges. Typical of an old projector tv
These will help
www.youtube.com/watch?v=esk4nYZKFcg how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
Mar 08, 2014 | Philips 60PP9202 60" Rear Projection...
I have a JVC AV-65WP74 65-Inch Widescreen HD-Ready Projection TV about 7 years old. I woke up this morning to a blurry picture with strong green outlines on faces and such. I went to adjust my...
It is not ha hard repair. The average shop repair is around 200.00, but the convergence ic's are you r problem. It does require soldering. if you have solder experience the STK ICs are not that hard to replace.
Feb 16, 2011 | Televison & Video
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
Oct 23, 2009 | Panasonic Televison & Video
Purple/Green Outline surrounding picture
I have seen two different things cause this. The first and most common is the electrical failure of one or both convergence IC's. A handful of times, the data in the DCU became corrupted and I was able to enter the service mode, go to manual convergence and correct the one location that was off.
Apr 28, 2009 | Toshiba 50HDX82 50" Rear Projection...
My Sony Big screen,57in.,Model #KP57WS510,the age-Feb.2004. I turned it on,it looks like i need a pair of 3-D glasses to watch it.Red and green outline the people or objects.Not so much in the...
The following convergence repair kit also applies to your model sony The kit contains the two convergence ICs all six pico fuses and four of the 4.7 ohm resistors. It also comes with free installation instructions and free tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
My phillips model 60pp920217f
You may have to do the full convergence alignment for all three CRTs, as outlined in the service manual for your model. Do you have the full service manual for your set which outlines the alignment and convergence proceedures?
May 08, 2008 | Philips 43PP9202 43" Rear Projection...
Samsung hl-p6163w
ussally when u get coloerd outlined this idicates ether a convergence or a focuse problem.. the green convergence has become shifted. not lineing up with red and blue.. this also could indicate a green crt problem.. my advice is to get a tech to check it out.. it could be a simple adjustment or a whole new green crt
Nov 16, 2007 | Samsung HCN653W 65" Rear Projection...
Tv has green outline
Hello fameus2,
Try to adjust your convergence from you menu items. If this does not work, the problem may be your convergence Correction ICs but make sure you try to adjust your convergence first. There is a lot of information on the net about how to change the two convergence ICs (so I will not reinvent the wheel here). I would however suggest that you get a qualified TV repair person to do this for you since some folks have run into other issues in trying to do it themselves.
I hope this helps,
Thank you,
Shuttle83
Oct 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Green Outline....
THERE IS NO WAY YOU CAN FIX IT WITHOUT SENDING IT TO THE REPAIR SHOP BUT IF YOU ARE A DIY PERSON YOU MIGHT BE ABLE TO FIX IT- ON THE NECK OF THE TUBE THERE IS MAGNETIC RINGS WHICH MUST BE ADJUSTED THE PROCEDURE IS CALLED CONVERGENCE WHICH IS NORMALLY CARRIED OUT BY SERVICE TECHNICIANS
Jul 12, 2007 | Sylvania 202SL8 TV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
