Question about Refrigerators
Ge profile pss26sgpa
How do I change the main board
catriver
  • 878 Answers
SOURCE: GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Posted on Dec 20, 2007
SOURCE: GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Posted on Jul 30, 2008
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
  • 351 Answers
SOURCE: We need for our GE
whirlpoolpartssurplus.com i can ship it out fast and give you a good price
Posted on Jun 23, 2009
SOURCE: GE pss26sgpa. Veggies in vegatable bin are frozen.
Replacing the damper and fan assembly worked for me. The damper had broken of from the actuator.
Posted on Feb 11, 2011
GE Profile PSS26SGPA side by side freezer is not cooling
Check freezer fan . Remove the rear cover in the freezer and see if you have defrost problem or ice build up
May 18, 2014 | Refrigerators
GE Profile PSS26SGPA Water Dispenser won't stop dispensing water
water shutoff valve bad or dirty,could be minerals in your water
Nov 23, 2013 | GE Refrigerators
Ice/Water dispenser not working on my GE Profile Arctica model # PSS26SGPA SS. Does make ice though, just front panel stopped working. Called a tech to troubleshoot, who said it was the main...
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Jan 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
Ge pss26sgpa. Veggies in vegatable bin are frozen. Raised temp to 40 degrees no efect.
May 15, 2010 | Refrigerators
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
I would like to knowe whats the perfect temperature for a refrigarator brand profile model pss26sgpa?
All brands of refrigerators is 35-40 degrees F in fresh food compartment. Freezer range is -5 to + 5 degrees F, depending on how hard you like your ice cream.
Sep 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
CallMe-
Best of luck.
Jul 28, 2008 | Refrigerators
Replacement of Interface Disp Asm. PSS26SGPA
Try using a putting knife, just apply slight pressure in different spots shoud just snap in.. cant break what already broke
Aug 16, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
