Question about Nokia 5200 Cellular Phone
Initalize my mobile
My mobile phone menu does not appear on the sreen since 4 days.Will be very glad if you could help
  • 3 Answers
Kode pengaman nokia 1661 imei 354183036994792
Posted on Jul 23, 2013
My Concord shuts down multiple times a day
May have a low memory issue going on.. Turn off any unnecessary features, and try pulling the battery out and putting it back in.. If that doesn't help, you my have to do a hard reset and restore it back to its factory condition... Here are the instructions to reset your phone: To perform a hard reset using hardware keys, follow these steps: Power off the device. Press and hold Volume Down key. Press and hold Power key until the Android and Triangle logo appears on screen. Let go of buttons once the logo appears. Press the device Home key. When the Factory Data Reset option appears, use the Volume keys to scroll to and select it with the Menu key. When Wipe data? appears, use the Volume keys to highlight Yes, and select it with the Menu key. Once Data Wipe Complete appears, use the Volume keys to highlight Reboot System Now and select it with the Menu key. Hope this helps...
Mar 05, 2013 | T-Mobile Concord
Dell a920, problem; does nothing, powelight keeps
Hi there You can try this not realy know if work on your printer it for a dell, it worth a go. How to clear NVRAM under maintenance:
· Press Menu.
· Press down until "Configure" appears, then press right.
· Press down until "Maintenance" appears, press right.
· Press down until "Init NVRAM" appears, and press right.
· "Init NVRAM Are you sure?": press "enter" in the center.
· Follow instruction and restart the printer (turn off the printer, and then on).
How to clear NVRAM under Network
· Press "Menu".
· Press down until "Configure" appears, and press right.
· Press down until "Network" appears, and press right.
Default username = admin
Default password = password
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Dell A920 InkJet Printer
Not starting
sound like your sreen is going out, try MD wireless or any other cell phone repair shop.
Aug 27, 2009 | Cell Phones
Brother mfc240c init 4F & init 5A
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Jul 18, 2009 | Brother Multi-Function Center MFC-240C...
49.4401 service error on start up
Solution or Workaround:
1) TRY to flash the firmware.
2) Try cold reset and disk initializations.
3) Replace firmware dimm.
If you have a hard disk:
To resolve the issue it may be necessary to perform the Disk Init procedure.
Disk Init Procedure
1. Turn the printer off, then on
2. When the memory count starts on the control Panel, press and hold the Menu button until all 3 lights on the control panel are lid
3. Press the < button. The message “INITIALIZE DISK” appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it’s power-on sequence.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP LaserJet 4650dn Printer
How can I format my nokia 7710 and re-install opertating system?
switch off your mobile phone, hold the three buttons of your phone. menu button, and another two buttons on the upper write side of mobile phone. switch on your mobile phone. do not unhold the three buttons until nokia logo come's [hand shake]. your mobile will formatted.
Apr 30, 2009 | Nokia 7710
Drum Full of Waste Toner
Try clearning the NVRAM most cases the drum fill count is baised on a setting and not if its really full.
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Nov 16, 2007 | Dell 3000cn Laser Printer
Errror message bootloader USB INIT. Help!
what you all need to do is have the firmware reflash on the phone....take it to a professional mobile tech or mobile service center
Nov 12, 2007 | Motorola Mobility RAZR V3
Wont recieve fax
NVRAM init NVRAM init returns all stored parameters in NVRAM to factory default values or to a default ROM value, depending on the variable, and performs a system reset. Performing NVRAM init can cause the product to violate local telephone regulations. Reset the language and country/region after performing NVRAM init. ENWW Service-mode functions 265 NVRAM init resets the following settings and information: ● All menu settings are reset to factory default values, including fax header and company name. ● Factory settings such as formatter number, page counts, and factory paper settings are reset. ● All faxes in memory are erased. ● All speed-dials, group-dials, and phone book entries are erased. ● All localization settings, including language and country/region, are reset. To perform NVRAM init 1. Turn off the product. 2. Press and hold down the * and MENU/ENTER buttons. 3. Continue to hold down the buttons while you turn on the product. Hold the buttons through the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When the message Language appears on the control-panel display, set the correct language and country/region. 6. Allow the product to return to Ready before using the product.
Jul 24, 2007 | HP LaserJet 3050 All-In-One Printer
Nokia 5200 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
