How to get rid of yellow and green paches from your laptop
Post your question under PC for
an answer
Posted on Jul 25, 2013
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
How to remove yellow and green paches from laptop
Your question is listed in the Cars and Trucks section. This is the wrong section for your problem.
Jul 23, 2013 | Computers & Internet
My laptop Toshiba Satellite model: PSA 60U-02K015. The problem is the system keeps going in a loop in safe mode. It will not go to any windows program. How and what is the problem. How to download any pach...
During start up does it give you any options to start it normally?
Try hitting F8 during start up to see if your able to get it to boot normally.
Not sure what "pach" you are talking about.
BIOS shouldn't be the problem.
Sounds like you have a virus of some sort.
Nov 02, 2010 | Toshiba Satellite A65-S126 Notebook
I need to find a VGA to HDMI pach cable and audo output also
A box like this should work.
You should also check ebay and shop around for the best quality / price around ;)
May 25, 2010 | Dell Vostro 1000
STARUP REPAIR V2 AUTO FAILOVER 6.0.6000L1686.6.0.6.6001.18000 6 10485992 BAD PACH BAD PACH 0 3 WRP REPAIR 2 LOCAL ID 1033
I assume your trying to figure out what this is. Basically a patch didn't take and needs to be done again. The problem you face is you may end up having to do a full install following a format of the main drive. If you received this message after trying to do a startup repair you are left with needing to do an install and I recommend you do a clean install by formatting the HD. You can try to an install over your current OS to save any information you may have on the HD but in most cases this is going to fail if you are getting this message.
Nov 20, 2009 | Acer Aspire 5100 Notebook
Sound does not work or to be more accurate works randomly after x restarts - sound works again
kindly install the proper sound dirver and install the service pach 3 also.
Sep 07, 2009 | Sony VAIO VGN-220E/B Notebook
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
No sound
u have to plug the speaker in green hole only.
Sep 02, 2008 | HP JBL Platinum Computer Speakers
Nokia N70 problems with phone ring
There is an sms ans ringtone pach on niokia n70 website. Try those
Apr 10, 2008 | Nokia N70 Cellular Phone
I need help to conected my linkyss router model wrt54gs at my conection dsl
Check if your Dsl is up and running. Your Dsl modem should have a green led with a green light that most be solit green. Connect a cat 5E pach cable from the back of the modem ( it look like a phone pug but it is big er ) to the back of the router, in the port that is label WAN.
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
