Exercise & Fitness Logo
Anonymous Posted on Jul 23, 2013
User manuals can a WW 70 operate without a monitor & disk drive? I have 6 beeps but no functions and no was to tell what service code statis
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Jul 24, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080769
Points
34431
Go to user manual www. fitness.manualsonline. com
God bless you
Set combination for paragon lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new pass code (3-6 digits long)
4. Immediately after entering your new pass code, press the "A" or "B" button on the keypad. Your new user pass code is now stored.
NOTE:
This safe stores up to 2 pass codes (a user code and a manager code). Entering a third code will erase the
first pass code entered.
SETTING UP OR CHANGING A MANAGER PASS CODE
1. Open your safe with the pass code you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user pass code.
New user pass codes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
tip
BIOS error, System Failure, Boot failure? ? Lets FIX it.
I guess everyone working on a computer is familiar with the word BIOS and what exactly it is? Still let me tell that BIOS is intelligent software that enables the system to start. I need not to mention that system here refers to computer. Bios facilitate the booting of a system without human intervention. BIOS is a program that is installed in a hardware chip known as ROM chip.
This single word matters a lot to most of the users who face various problems when their system failed to start normally or make some unusual activities. Each time I visit any technical forum I see a lot many users posting their problem regarding BIOS. I researched on internet about BIOS errors and from my knowledge and experience I am posting this piece of help for those who find themselves helpless in getting a solution to BIOS problems.
Sometimes BIOS itself provide a troubleshooting to most of the problems. When you power ON your system it give beep sound. Checkout some beep codes
1 short Beep indicates System is OK (Acceptance Beep)
Continue long Beep tells RAM Problem
1Long 3 Short Beep confirms RAM Problem
2/3/4 short Beep --its time to Check the RAM & Video Card
By now most of you have found some clue about the problems you are facing. Now learn about POST faults
1) K/B Error/ NO Keyboard present
· Check the loose cable connector
· Cable may be bad (Keyboard)
· K/B itself may be bad
· Check the physical condition of K/B connector on M/B
· If all these are ok & problem is still processed
· Than replace the keyboard port
2) Floppy disk drive Fail
· loose data & power connector of FDD
· Data cable may be bad (FDD)
· Load the CMOS defaults
· Floppy disk drive itself may be bad
3) CMOS Checksum error
· CMOS battery has gone bad replace it. (Weak)
· Check the CMOS jumper it may set on clear
· If the entire ok than check the CMOS battery jack, it may be bad
4) Invalid System Disk, Insert System Disk & Press enter when ready/ NTLDR is Missing
· Check the root directory; it may be formatted or missing bootable files.
· Repair the Windows or Reinstall the operating system.
5) Disk Boot failure, Insert System Disk & Press enter when ready
· Hard Disk check in POST Detected or not
· If not Detected Check the power cable
· Check the Master/Slave jumper setting.
· Also check BIOS setting
6) Computer gives message: Your computer has a serious problem
Back up your data & replace your Hard Disk
This error message is displayed due to the SMART option. This scans the HDD for errors, if it detect the errors than it show the above message. Follow the error message & back up your data on to another drive.
I tried to explain most of the problems along with their solutions. There could be a lot more solutions for the problems. Make your own search and try to fix BIOS problems at your own home.
Forward this to all those who need help!!
SOVI
on Feb 09, 2011 • Computers & Internet
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
6 beeps and #1 & #2 flashing when I turned It on. Will not operate now. Help?
can try my tip under WW 1000 or contact Geo. Beyers Co. @ 800-392-8085 for a KB rebuild. Tell them O'Reilly sent you.
DickyO
1helpful
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
2helpful
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4helpful
2answers
Manual. need to know what the connections are for
User guide or Manual for Amstrad Sky+ ...YYY
2 posts - 2 authors - Last post: 27 Jun 2007
I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ...
forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages -
Sky Digibox remote control codes for your television
This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ...
www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages -
User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ...
User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ...
safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages -
For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com
Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ...
www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages -
Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums
6 posts - 5 authors
Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ...
www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages -
amstrad sky plus on standby
Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ...
www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages -
sky+ box keeps making beeping noise. - Cable Forum
15 posts - 3 authors
can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ...
www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages -
Sky+ box amstrad dx280 - FixYa
Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ...
www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages -
MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box
Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ...
www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages -
Amstrad DRX 180 - Review - How did we live without it???
The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ...
www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
3helpful
2answers
6 beeps on start up, no video
Without knowing what yo have for a BIOS, it is difficult to diagnose. The below link is a list of beep error codes for different BIOS types. Check your BIOS to see if it is one on the list and see what it means:
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=guide_beep_codes
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
