Question about Husqvarna Garden
What do steering dampers do on zero turn morews
How do i adjust my steering box for my 1998 grand jeep cherokee
check to see if you have a steering damper (shock absorber) that is restricting steering. wrong one installed
Nov 14, 2011 | 1998 Jeep Grand Cherokee
I have a Land Rover Discovery 97 that gets a bad wobble in front end at 55 mph, only happens when driven over bumps or uneven pavment.
It will be the steering damper, now, if you have replaced this recently, then the damper is propably fitted at the wrong angle, instead of being straight ( horizontal ) it should be pointing down at an angle. If you have not changed the steering damper, then i suggest that you do. In my experience, i would not recommend Monroe steering dampers fror Land Rover, try to get Old Man Emu,, Bilstein or Woodhead, or if there is a Britpart supplier, i can recommend the Cellular Dynamic. Hope that helps
Mar 09, 2010 | 1997 Land Rover Discovery
Rattling in the steering wheel, horn honking by itself when i turn corners, and hard thump when turning. Dad thinks it may be a steering wheel damper. Heavy steel, u shaped piece held in by three rubber...
its probably the coil spring contact just below the steering wheel.Its the electrical connection for your horn ,airbag and speedcontrol switches.
Feb 01, 2010 | 1992 Ford Explorer
Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Apr 18, 2009 | Garden
1990 cherokee shakes badly only at 50-55mph
Check the front steering damper. The steering damper is a shock that is mounted horizontaly in the front. The damper is bad if you see oil leaking from it or if the car has high mileage and never been replaced.
Feb 16, 2009 | 1990 Jeep Cherokee Limited
Need diagram for assembly of steering stabalizer(damper) 1994 toy
try this link, scroll down & click on steering linkage, then scroll down & click on picture to expand view.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280061310
Dec 11, 2008 | 1991 Toyota Pickup
Steering damper
the steering dampner connects to the side car mount that connects to the frame on thetop of frame and hooks to a plate that bolts to the forks where the air deflector bolts I ride a sidecar eqpt, flh2002
Nov 30, 2008 | 2003 Harley Davidson FLHTC Electra Glide...
Steering whel vibration isuzu bighorn 3.1d 1992 auto
Some SUV's have a steering damper. This is like a telescopic shock absorber that is attached to the steering idler arm at one end and the chassis at the other. If the bighorn has one this may be the cause of the problem. It took me months to find a severe steering vibration problem on a Range Rover. I replaced the damper, which was quite inexpensive, and the problem went away.
Oct 10, 2008 | 1999 Isuzu Trooper
Garden Logo
102 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
