Question about Garden
Awnings open my luxoflex awning has opened and it will not retract, although i can hear it clicking when the remote is pressed
SOURCE: How do I get an instructional manual for the awning on my RV?
kindly download the manual from the following website
http://bryantrv.com/owners.html
thank you
Posted on May 18, 2009
gemmy23
  • 346 Answers
SOURCE: Looking for bottom mounting brackets for Coleman
Maybe these websites will help. The first one has a huge selection of parts. I am pretty sure you can find what you are looking for at one of these places. If they can't help you please let me know and I will keep looking. They are:
http://www.go-rv.com/coast/do/catalog/main?dealerId=66
http://www.marksrv.com/ultrahardware.htm
Posted on Aug 11, 2009
  • 234 Answers
SOURCE: Have an awning with control panel model no
I'm not sure why you are asking this question; assuming you have aready looked for a manual winding feature. Some models have a cover plate that must be removed to access the manual wind device, however you will need a winding crank/handle that fits into the wind device. As far as the auto mechanism not working, 1st check to see if the electic is still coming to the unit ( was there any disruption to the electric line or wall work that would make the line be disconnected or the circuit breaker ? If you still have problems, l please return with a more detailed list of what you tried and what is/is not happening..
Good luck, Macgivor
Posted on Oct 24, 2009
  • 3 Answers
SOURCE: safetech triple jogging stroller awning
You can get some velcro and attach a piece of thick netting to extend a little further past the sunshade, kidof like a visor, My other triple had the netting as a removable extender, I think that it would work for the safetech also.. :) Hope this helps.
Posted on Jun 28, 2010
iujknwertgrt
SOURCE: parts for SunSetter Model 1000
Try on amazon. take a look here Amazon com SunSetter parts. If you can't find out exact part, contact come vendor and ask... (probably someone will deliver what you need). regards
Posted on Nov 24, 2014
The awning has two rollers and is manually operated, but we can't figure out how to use it
Teresa, I will post links to videos on awning set up and use. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Use the Awning on Your RV
RV Awning Tutorial
1 How to Open RV Awning
How to Use and Maintain Camper Awning Pete RV Service Tips
May 25, 2016 | Dometic A&E and Carefree 18 Universal RV...
How do i open awning?
Climb ladder and hand roll it out until you can hook it
May 16, 2015 | RVs
Motor Home Door Awning
When you press the operation switch do you hear the motor clicking or trying to operate? If not you need to determine if you have power going to and through the operation switch. These motors usually have an inline circuit breaker that will need to be located. Some of the circuit breakers automatically reset themselves and some have a small button on the side that will pop out when tripped. Once you determine that you have power to the motor and it still does not work then you more than like have a bad motor and will need to manually override the motor to bring the awning in. The awning should have a manual crank that will allow you to connect to the center eye of the operating gear and manually close the awning. I have attached the installation and operating instructions for your awning. http://67.238.126.140/pdf/3307901.011.pdf
Apr 14, 2014 | Dometic 975CQ Elite Oasis II Power Door...
Awning retracts at random
some awnings have a sensor that retracts the awning if wind elevates to certain level. i wish mine did. i have seen them ripped off rv's.
Jan 19, 2014 | Dometic Heating & Cooling
Aristocrat retractable awning is drooping
lock the arms if ok add spring tension
Nov 10, 2013 | Sport & Outdoor - Others
Dometic Awning motor burned out
Check out for the brushes in the motor. They might be worn down and need replacing.
Apr 05, 2013 | Dometic A&E and Carefree 18 Universal RV...
My A&E 9100 Power awning has had a motor go out twice in three months,
Yep ~ exposed wires to the weather elements PLUS the stress and flex-action as you open and close your awnings can quickly lead to disaster (again)!
Perhaps a GENEROUS amount of clear (tube) RTV SILICONE applied to the wire access hole/point AT your Motor?
Since you are replacing MOTORS often ~ perhaps the real cause failures are the MECHANICAL FLEXIBLE JOINTS of your AWNING ~ (being) too stiff offering too much mechanical resistance to your MOTOR?
> YOU DO< have a lot of them so CAREFULLY spray just enough 'garage door lubricant' to them to assure minimal resistance to awning movement and motor movement!
Also it seems that everybody ~ including your motor mfg. ~ wants to save a buck so they substitute smaller wires (internally and externally) or any other 'trick' that will shave down their costs! So try to hunt for a older (new) motor... perhaps that will extend the life of same...
Sadly your motor looks rather specialized so finding a beefier / stronger replacement (at less cost) looks like slim chances... I was thinking of maybe a older satellite 'C-Band' dish motor? Those puppies are STRONG and built to handle LOTS of TORQUE-stress due to HIGH wind issues on the surface. DIsh motors are also VERY reasonable in cost!
Do you have a 'machine-shop friend
d that can help and make special brackets ~ and perhaps modified motors may be your ultimate answer?
Sep 18, 2017 | Computers & Internet
Garden Logo
221 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
