Question about Acer Computers & Internet
Centos 4 0
Display is very dim while installing centos 6.4...
    Problem Solver:
  • 14 Answers
What OS are you using now? Is it dim? Have you looked in BIOS for brightness settings? Maybe they need to be turned up during the install. Have you made it through an install of CentOS, and if so, is the running OS dim?
Posted on Jul 24, 2013
Replace dimmer switch for 2007 Buick Lacrosse
Are you sure you want to do that ? Are you guessing that's the problem ? Do you know what DTC'S - diagnostic trouble code's are ?
DTC B2610
The body control module (BCM) applies a voltage reference through the instrument panel (I/P) dimming voltage reference circuit to the interior lamp switch. When the switch is placed to the desired position, the dimmed voltage setting is applied from the interior lamp switch through the I/P dimming return circuit to the BCM. The BCM applies the dimmed voltage to the I/P lamps supply voltage circuit.
Do you know how to do electrical testing ?
Reconnect the lamp switch assembly.
Disconnect the body control module (BCM) connector C1.
Using a DMM, measure the resistance between the I/P dimming voltage reference circuit and the I/P dimming control circuit.
Vary the I/P dimming switch from full bright to full dim.
Does the DMM, display change?
Did you perform the Diagnostic System Check - Vehicle?
Yes - Go to Step 2
No - Go to Diagnostic System Check - Vehicle
Verify that the interior backlighting does not dim.
Does the interior backlighting operate normally?
Yes - Go to Testing for Intermittent Conditions and Poor Connections
No - Go to Step 3
Do the instrument panel (I/P) lamps dim?
YES - Go to Step 13
No - Go to Step 4
Do the class 2 lamps dim?
Yes - Go to Step 5
No - Go to Step 6
5
Test for a short to battery positive voltage in the I/P lamps supply voltage circuit. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Yes - Go to Step 14
NO - Go to Step 13
6
Disconnect the lamp switch assembly.
Does all the illumination of the backlight components turn OFF?
Yes - Go to Step 8
No - Go to Step 7
Nov 18, 2016 | Buick LaCrosse Cars & Trucks
Can i install a used instrument panel in a 2001 volvo v70?
You can replace it with a junkyard one but there are issues. Best to get it repaired:-
To install/replace the D.I.M.(Drivers Instrument Module) easily. Disconnect the battery. Remove the plastic surrounding the D.I.M. by pulling it. You will then see 4 T25 screws. Remove them and carefully lift the DIM forward and out and avoid scratching the display. Disconnect the display. If the display has failed and is giving you total random readouts, it needs replaced/repaired. Getting it repaired at the dealer will be MEGA bucks.....but there is a cheap solution. There are many companies around that will repair if for you for a fraction of the cost without the aggro of mileage correction issues. (see eBay)Alternatively, reflow the Motorola chip on the circuit board yourself if you know how to. When repaired and refitted, re-connect the battery with the ignition switch in position 2.
Oct 09, 2013 | Cars & Trucks
H611cafe can't install linux
It sounds like the CentOS team doesn't have all the drivers ready for your motherboard yet.
Jun 01, 2012 | Asrock H61ICAFE LGA 1155 Intel H61 HDMI...
I am unable to install centOS 5.5 or openfiler to a supermicro server with an areca 1210 controller. The lofigal volume size is 200MB (the drives are actually 2TB each, but I carved out a 200mb part for...
http://www.areca.com.tw/products/pcix.htm
i think you must see this specification first, and then you will know why your centOS unabled to install areca ARC-1210 serial ATA controller, if you was see at that site, it describe that areca Software Drivers arrow.gif Windows 7/2008/Vista/Server 2003/XP/2000 arrow.gif Redhat Linux and SuSE Linux arrow.gif FreeBSD arrow.gif Solaris 10x86 arrow.gif UnixWare 7.1.x arrow.gif Netware 6.5 arrow.gif Mac OS 10.4.x/10.5.x/10.6.x (EFI BIOS support)
i hope this helpfull
please rate my answer
thanks
Dec 24, 2010 | Areca ARC-1210 Serial ATA Controller
How t format a pc with centos os?
The formatting and installing the PC with the centos is similar to the other Linux operating systems .
Initially insert installation cd and boot the computer and with the help of GUI you can perform the formatting and installation .
Installing centos is similar to rest of Linux operating systems
The detailed steps can be found from tyhe following link
http://www.howtoforge.com/installation-guide-centos5.1-desktop
May 05, 2010 | Red Hat Enterprise Linux ES Basic Edition
On linux centos it doesn work
The CT4170 SoundBlaster "Vibra" cards are old 16-bit ISA PnP cards, and were not detected at install by Linux kernels 2.16.15-27. You need to get the "isapnptools" package from the Fedora or CentOS sites, and do the following:
2. Install isapnptools using dpkg -i path-to-downloaded file .
3. Create and edit file /etc/isapnp.conf and put the following contents in it:
(READPORT 0x0273)
(ISOLATE PRESERVE)
(IDENTIFY *)
(VERBOSITY 2)
(CONFLICT (IO FATAL)(IRQ FATAL)(DMA FATAL)(MEM FATAL)) # or WARNING (CONFIGURE CTL00f4/-1 (LD 0
(INT 0 (IRQ 5 (MODE +E)))
(DMA 0 (CHANNEL 0))
(DMA 1 (CHANNEL 1))
(IO 0 (SIZE 16) (BASE 0x0240))
(IO 1 (SIZE 2) (BASE 0x0300))
(IO 2 (SIZE 4) (BASE 0x0388))
(NAME "CTL00f4/-1[0]{Audio }")
(ACT Y)
(WAITFORKEY)
4. Run "isapnp /etc/isapnp.conf". If it reports errors, you must change configuration above (it is suited to my setup). Try "pnpdump -c" and put its output in /etc/isapnp.conf file. If it does not help, you must find the correct configuration manually, for example change port to 0x220. For full list of possible values run pnpdump. Note that if you change the configuration, you must change options for modprobe below.
5. Create and edit file /etc/modprobe.d/sbvibra and put the following options in it:
alias snd-card-0 snd_sb16
options snd_sb16 port=0x240 irq=5 dma8=0 dma16=1 isapnp=0
6. Run "update-modules"
7. Run "modprobe snd-card-0". If it works OK (check if "ls -l /dev/dsp" shows that file is present), perform the steps below to make setup permanent:
8. Append following line to /etc/modules:
snd-card-0
8. Go to system configuration (in GUI) and choose "Services". Enable "isapnp" service and tick option to start it at boot.
Hope this helps :)
Ted
May 23, 2009 | Creative Labs CT4170 Sound Card
Acer travelmate 240 linux bluetooth problem
I have an acer travelmate 240 running centos 5.It has bluetooth but I dont know how to install it.I need help.
Jul 13, 2008 | Acer TravelMate 240 Notebook
Computers & Internet Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
