What does the "9" Light Indicator mean on a Dell
    Sergeant:
  • 396 Answers
Check to see if the keyboard is typing the correct letters. That should be the numlock indicator to make the keys change from letters to numbers. This is explained on page 24 of your user manual.
Posted on Jul 24, 2013
  • 120 Answers
SOURCE: i want to reboot my
Reboot? You mean restart? Click Start, click the arrow beside the Lock button and choose Restart. It's the same.
If you mean System Recovery (wiping out everything but the OS and making the PC new), then there must be a software like Recovery Manager. Search Start Menu.
As it is a Dell, you must have a recovery partition on the drive. It will be just as new.
Or use the set of CDs that you created when it was new, or one which you got with the PC. If you didn't get and you didn't even make it, ask Dell to send a set for your model.
If nothing works, then use a Vista installation disk that you can buy in a retail store. Note that you won't get the pre-installed software that you got from Dell when you removed the PC from the box.
Posted on Nov 28, 2008
stif_NEC
  • 441 Answers
SOURCE: Dell XPS M1330 PC Notebook can't connect to the external monitor
No. You just basically need a VGA cable. Check your video settings.
Posted on May 06, 2009
Geekman
  • 32281 Answers
SOURCE: passward broken
Unless you can get hold of a Linux password recovery program to reset or remove the password from the Windows Administrator's login, you will need to reinstall Windows again, the device drivers and your programs.
In this process you will lose all your data that is stored on your hard drive.
If you want to save your data before you install Windows, remove the hard drive, connect it to an USB hard drive adapter (most likely you will need power to the hard drive) and plug it into the USB port of a working computer. This computer will see it as an external hard drive, copy your data you require so you can load it back onto your computer after you installed Windows.
OR
You can connect your hard drive into a working computer on the 2nd IDE controller, then you can see this drive and copy your data files.
Posted on May 21, 2009
SOURCE: Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
I have one dell xps m1330 laptop. These are few days my laptop has getting some problems. When I on my laptop it will appear blue screen. I can’t see anything. I had change hard disk and Ram. Some times I have switched on my laptop that time ask press F1 or F2 or F5. When I press F1 it will go to window. What is actual problem? Would you help me?
Posted on Jun 20, 2009
  • 1456 Answers
SOURCE: my Dell xps m1330 won't power on , the light on
what you are experiencing is a problem from your motherboard.. try opening it up and check for burnt smell. get someone with a bit of experience to open it up for you and you will have to get it changed
Posted on Feb 14, 2010
I cant get my disk out of my xps m1330 laptop what do I do?
Have you tried using the Eject button on the controls above the Function keys on your Dell XPS M1330 laptop to eject the disk from the optical drive?
If the above does not solve the problem then you may need to refer to the Service Manual for your XPS M1330 which has information on how to remove and replace the Optical drive if this has failed.
Jan 05, 2012 | Dell XPS M1330 Laptop
The sreen of my DELL XPS M1330 suddenly does not lght up!
It can be either the display is dead or it is a loose connection. If you are still covered by warranty then I would suggest you to contact the dell technical support. They will replace the part for you.
However if you don't have a warranty then you can buy this part from dell online store (the display) and you can fix it on your own - http://ahwee.com/how-to-disassemble-laptop-dell-xps-m1330 follow the instructions here to dismantle your laptop and refix it with the new parts. If you find any troubles doing so; please let me know; I will help you further.
Best Regards NextDoorNerd
Jul 28, 2010 | Dell XPS M1330 Notebook
Dell XPS M1330 battery not detected!
Normally the life time of a laptop battery is 300 cycles. that is 300 discharges and charges. Since your laptop is almost 2 years old, the battery could be at the end of its life time, and again depends on how often you use your laptop in a day. Better goto a service center or get a similar battery from any of your friends just to make sure it is not a motherboard issue. Then you can think about which part you've to replace.
Please come back and rate my solution if it turns to be helpful fro you, or also if you need more clarifications. Thnx
Apr 01, 2010 | Dell XPS M1330 Notebook
Dell XPS M1330 doesn't recognize original power cord after 2 yrs
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 09, 2009 | Dell XPS M1330 Notebook
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
Jun 01, 2009 | Dell XPS M1330 Laptop
Dell xps m1330
The M1330 is not in stock anymore at Best Buy, here is a choice of Dell laptop different models that can be purchased online.
Jul 29, 2008 | Dell Inspiron XPS Gen 2 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
