HOW DO YOU CHECK THE VIDEO SETTINGS? - Computers & Internet
Carefully
Posted on Jul 23, 2013
I HAVE A NEW HP ALLIN 1 WIDOWS 8. ON FACEBOOK VIDEO CHAT THEY CAN HEAR ME, BUT I CAN'T HEAR THEM
Launch the Logitech QuickCam or Webcam software on your computer. Verify that you see yourself Logitech Webcam software window. Close the software window. Sign in to Skype. Click the "Tools" menu and select "Options." Click "Video Settings," check the "Enable Skype Video" and "Start my video automatically when I am in a call" boxes. Select your Logitech QuickCam from the drop-down list. Your webcam should display video in the window. Click "Audio Settings" if your QuickCam has a built-in microphone and select it from the microphone drop-down list. Check the "Let Skype adjust my audio settings" box in "Audio Settings" so Skype recognizes your microphone. Click "Save" to save the options for your audio and video settings. Skype will close the options menu.
Jan 28, 2013 | Logitech Quickcam Chat Webcam
Tip
SKYPE VIDEO PROBLEM
SKYPEVIDEO PROBLEM
To test if the WEBCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - your model WEBCam and see if you can get the WEBcam to capture your image/video. If this works then the fault is with the Skype video configuration. Sometimes the WEBcam settings drops off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select your model WEBCam.
Also check the Audio Settings for your model microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub, connect it to the USB port on your computer.
on Oct 23, 2010 | Computers & Internet
Game is slow and freezes
try to check your video settings . try to lower ur video settings to medium and try to the game. if problem persist try reinstalling the game. also check your video card compatibility with the game.
Jul 03, 2011 | Dreamcatcher War Leaders: Clash of Nations...
No color display when i play DVD thru component.
First, check the settings on the DVD player's setup menu for output. Make sure it's set to either Component or Y YB YR or YBPR, and not to "Video". If your settings are correct, check the component cable and make sure it's plugged in correctly on both sides, TV and DVD. If still having a problem, try a new cable.
Finally check the input settings on the TV, if you still have a problem, try using a basic Audio Video cable on the Video out of the DVD to Video 1 in on the TV. That's about as much as you can check. If all fails, if possible, connect the DVD to another TV to check for the same problem to determine if it's a DVD player problem or a TV input problem. Hope this helps!
Jun 01, 2011 | Televison & Video
My Toshiba 55HT1U is showing 480p instead of 1080p. Why is it not on 1080p?
It is probably your video source. If you are using component video, some devices only output 480p.
Check the settings of your sources. The TV will display only what the device sends to it.
In most devices under a settings directory there will be settings labeled "Video" or "Resolution" Changing these settings to more appropriate High Definition resolutions should solve your problem.
Mar 17, 2011 | Toshiba 55HT1U LCD TV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Cannot improve quality of personal videos.
Try the below steps.
You can try adjusting the video settings of your Windows Media Player:
  1. On the menu tab, select View
  2. Select Enhancements
  3. Select Video Settings
Under video settings you can adjust the brightness, contrast, color settings, etc.
You can also check on the video size:
  1. On the menu tab, select "View"
  2. Select "Video Size"
I think this will helps you.
Dec 16, 2010 | Microsoft Windows Media Player
I have a Logitech QuickCam 6.0 and it has been working perfectly for months with Skype. Now I am still receiving incoming video but outgoing no longer works. I reloaded QuickCam without improvement. ...
Try to check if this issue occurs on Skype only or with all programs
If it is for Skype only:
You need to check the Video Settings in Skype.
Start Skype > Options > Video Settings > select the webcam that you are using.
If the webcam is not on the list, download and install the driver from the manufacturer website
Try to set Automatically Receive Video from - select Anyone or Only people in my contact list.
Jun 01, 2010 | Logitech QuickCam Connect Webcam
I have a skype account and so does my daughter. We each have a web cam. She can see me when we dial one another, but I cannot see her. Can anyone tell me what we are doing wrong?
Here's a sollution:
1. Click on Skype Menu Tools -> Options.
2. In General section on the left press Video Settings.
3. Check Enable skype video check box
4. Check Star my video automatically when I am in a call check box
5. Select webcam from the drop-out menu
6.You may check webcam settings by pressing button Webcam Settings
7. If you can't see your video in rectangle on the right, check whether your webcam is correctly installed (driver) and connected to the PC.
8. Check Automatically receive video... from anyone or only people in my Contact List check box.
9. Save your changes
Also you might need the latest version of DirectX to use skype video at http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&DisplayLang=en
Jan 23, 2009 | Computers & Internet
Video Settings
Hey there,
I remember reading about this in my manual
It's under one of the TIP! sections, on page 46 under the 'Video Camera' topic. It says the following;
  • "When you exit the video camera all your settings will return to default, except Video Size and Video Quality. Any non-default setting you require will need to be reset, for example colour tone and white balance. Check them before you shoot your next video."
Same applies to the Camera settings on page 43;
  • "When you exit the camera, all yours settings will return to default, except image size and image quality. Any non-default settings you require will need to be reset, for example, colour tone and ISO, Check them before you take your next photo."
Hope this helps!
- Ness. :3
Oct 29, 2008 | LG Secret ? KF750 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
