Question about Cell Phones
When I connect my memory toPC I show memory card format and when I format its didn't format
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cell Phones Master
  • 102,366 Answers
What type and size memory card? Is it compatible with your memory card reader?
Posted on Jul 23, 2013
  • 17 Answers
SOURCE: I can't able to format my memory card..it shows
Make sure your card has only the amount of gigabytes that the phone indicates. It will not format if you are trying to use a card with more memory than the phone allows.
Posted on Oct 11, 2009
asber
  • 291 Answers
SOURCE: memory card corrupted
try to format it with low level formatting tools, google it to download. but if it doesn't format at all, it only means you need to replace it.
check also if you use a password for your memory card before. if you use some password, then, it will not be recognized by the system.
Posted on Feb 20, 2010
  • 87 Answers
SOURCE: I m not getting the format option for the memory
your memory card is corrupted and it cant be solved.buy a new memory card otherwise using the same will also corrupt your phone
SOURCE: My Motorola L7 cannot read the memory card. can't format either
You can try formatting on a PC, and try and use it then. Format it FAT32. and it just may work. If NOT it maybe faulty, your phone, may not "Like" that brand of MC,. try another. or the camera itself is faulty.
Posted on Apr 15, 2010
SOURCE: my nokia 2690 mobile always
to proto ?e mate plnou pam?t ty zpravy se nemaji kde ulo?ovat
Posted on Jul 26, 2011
I have a 2gb micro SD card, I am trying to format it but it didn't formatting in mobile as well as in PC also
click start click on my computer you should see your 2 gb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your 2 gb drive select format
hope this helps
Sep 17, 2012 | PNY 2GB microSD Memory Card
What happens if I didn't format my sdhc memory card and just started taking pics with it?
Exactly what happened to you. You start getting card errors and can't read/write the card.
Jun 29, 2012 | Lexar Kodak SDHC 8 GB Class 4 Flash Memory...
Lost all memory on a 64gb sd micro card after formatting
No, you didn't loose memory. You just have to reformat it. When you do, check if you can change the total capacity with drop down menu, also try settings it to FAT32.
If not, you could use another computer or even a portable device like cellphone or camera to try and format it.
Don't worry, you cannot 'loose' the 64gb.
Jun 19, 2012 | SanDisk Electronics - Others
Loading pictures to a computer
Denise - you didn't provide *any* details so the help I can provide may be rather limited, but here goes:
You can transfer pictures to a computer a couple of different ways. The first method requires that you install any software that came with the camera on your computer and reboot. Next, connect the camera (powered off) to the computer with the included cable - which is almost always a USB type on one end and one that fits into your camera on the other. The camera will need to have working batteries, so be sure that they're good. Turn the camera on and the camera software should automatically detect the camera and start up. You should be able to transfer, possibly edit and save your pictures on the computer. If you didn't receive software with your computer, skip the software installation step above - but do the rest. Double-click the Computer icon (to show you the hard drive and DVD/CD icons) and look for a new drive. The new drive represents the camera memory. You can open the drive and work with the picture files just like they were files on a hard drive. Move, edit, copy, delete or save them as you see fit. The drawback to this method is that transfers from you camera are often slow and of course you need batteries. A second method is not limited by these - but does cost money. Keep reading.
The second method requires the use of a "card reader"
An external USB multi-format card reader.
Card readers are powered by and transfer files via the computer's USB port. They run at significantly faster speed than the camera and can be purchased for as little as $10. To use them, install software included with the reader (if any) and reboot. Connect the reader to the computer's USB port. Remove the memory card from the camera and insert it into the appropriate slot in the card reader. A message stating that a new device has been found and software is being installed will appear on the monitor. Double click the computer icon and look for a new drive icon. Double click the new drive to show the image icons on the memory card. Move, edit, copy, delete or save them as you see fit. When done click the "Safely Remove USB" icon in the System Tray and then click Remove. If you don't see this - simply remove the reader from the USB port or the memory card from the reader slot and you will be shown how to do it properly the next time.
Be sure to FORMAT the memory card after you insert it into the camera before shooting new pictures. Formatting the card on your computer is not the same - and should be done in the camera. Formatting removes ALL data from the memory card, so if you wish to leave images on the card to show others on the camera - do not format. As mentioned above, the format should be done before taking new pictures.
Nov 27, 2011 | Nikon D Cameras
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Put memort card in camera,,didn't realize I had to format disc.followed instructions in book to format but does not tell me it is formatting,,, still get unsupported card message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 27, 2011 | HP Photosmart M417 Digital Camera
Hi Sir My CANON A470 it shows memory card is locked & memory card error, most of the file are in it how should i retrieve it, i ve tried with new batteries also.My PC also doesn't support it
Sep 17, 2011 | Canon PowerShot A470 Digital Camera
I've had the Samsung L200 with the same Panasonic 1GB memory card for the last 3 years and it's been great, but all of a sudden today it started saying 'memory full' after only taking a few...
The camera is telling you that the internal memory is full. To get your card to work, you must clear it. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, your card should work unless you formatted it in the computer, in which case you'll have to format (completely erases it) it in the camera.
Aug 21, 2011 | Samsung L200 Digital Camera
I viewed pictures on my computer and didn't upload them. When I placed my sdhc card back in my camera it gave me the error message "memory card error" and "card locked", however the...
Don't be panic. you can try some data recovery software. You can see
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jul 15, 2011 | Cameras
I am currently using a cannon a480 digital camera with a 2gb memory card. i just inserted my memory card into another camera (benq dc2410) and it said card error, needs formatting. now when i placed my...
As long as you didn't format the card your images should still be in there. Get a card reader (usually like $10) and connect this to your computer. With this you can just drag and drop the images to your desktop. Once you do that format the card on the camera you want to use it with and don't use it on any other devices. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon PowerShot A480 Digital Camera
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
