Question about JVC KD-NX1R CD Player
Unlock code radio for JVC auto radio kdnx1r
My JVC car radio is lock
Free unlock code car radio
Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service
It is unlikely to be available for free or cheap from anywhere on the Internet
Oct 22, 2013 | JVC Car Audio & Video
Buick Lacrosse stereo unlock code
you are going to have to go to the dealer to get the codes for it. you may not be able to unlock it because most of the radios today from gm and unique to the car. they go by the vin number to get codes.
Jun 16, 2013 | JVC AM FM CD DET FACE CAR STEREO
2005 Chevy Cavalier, get code out of radio to get unlock code from GM
oN STERIOS THIS NEW YOUR ONLY CHOICE IS TO TAKE THE RADIO TO THE DEALER AND HAVE THEM SHIP IT IN TO THE FACTORY FOR REPAIR AND WHEN YOU GET IT BACK YOU WILL PROBABLY HAVE TO TAKE IT TO THE DEALER TO HAVE IT PROGRAMMED
Apr 06, 2013 | Chevrolet Cavalier Cars & Trucks
How to turn off clock on jvc tv
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Sep 06, 2012 | JVC Televison & Video
Sep 06, 2012 | JVC AV-32260 32" TV
Remove the prerental block on a jvc tv
Apr 03, 2012 | JVC Televison & Video
Change time on car radio model kd-g220
1. Press and hold "select" on the faceplate until the display changes.
2. Using the up/down rocker switch at the right of the faceplate, cycle through the PSM (Preferred Settings Menu) until you get to "Clock H".
3. Use the dial control (left end of faceplate) to select the hour. Note that it's not a 24h clock, just 1 to 12 are available.
4. Use the rocker switch to select "Clock M".
5. Use the dial to select the minute from 00 to 59.
6. Press "select" to return to regular operation; you may wish instead to use the rocker switch to cycle through other PSM options for the dimmer, scroll and woofer.
If you want more details then you can download the manual from JVC here.
I hope that you have found my posting to be of assistance, all I ask in return is that you return the favour by rating my answer. If you still have not solved your problem then add a comment instead and I'll offer further help.
Nov 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
I need unlock code
jvc radio no use lock code, try push reset botton, is a little boton-- push with a pen tip for 2 second.
May 16, 2009 | JVC KDS-30 CD Player
CODE TO UNLOCK JVC CAR RADIO
need code
JVC CAR RADIO MODEL KD-LX110R
serial no. 17600125
Dec 14, 2007 | Car Audio & Video
JVC KD-NX1R CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
