Question about Mtd 22" Yard Machine Push Mower
Cable assembly details
The mower was given to me missing it's throttle cable . When I put in one I had it's somehow reversed . I.E. the sleeve plugs into a hole in a bit of angled metal and the cable with the "l" shaped end fits in the smaller hole of the adjacent housing which should move to allow the engine to operate until the handle at the other end of the cable is released BUT " no " because the "L: shaped end connection does not move , it's the part where I have the sleeve connected that does . I can't figure it out and the model # on the machine is gone . Any suggestions before I trash the thing ?
  • Paul Giroux Jul 25, 2013
    Problem solved . I was looking at the cable the wrong way , expecting the cable to be the operating part and not the sleeve . Working fine now !
    Problem Solver:
  • 14 Answers
Is it the brake cable ? when you release it, it brakes the engine and stops running, make sure you zip tie the cable down securely to mower handle also.. try sears most of them are made by MTD
Posted on Oct 29, 2013
rburroak
  • 14 Answers
SOURCE: Pull rope snapped on my Yard Machines 4hp 22in push mower
There should be 3 -3/8 or 7/16" bolts on the side of mower (where the spark plug is, there should be one) the other two will be just opposit of the two. Remove bolts and housing should be free.You might to remove any cables to free up any slack.
Posted on Jun 19, 2009
  • 138 Answers
SOURCE: Mower starts, but dies immediately
that's not a choke lever, it's used as a speed control on some models. the two springs are attached to the governor rod, which is attached to an "air vane" governor - on these engines, you need to keep the gas tank fairly full at all times, the dip tube on the carburetor rides up off the bottom of the gas tank, if fuel level goes lower than this tube, it won't pull any gas to the intake - from your descriptions, though, it sounds like the diapragm between the carb and gas tank has "curled". briggs had a service flash on the problem and since it's new, you should take it to a shop that does briggs warranty work - it should be covered under warranty
Posted on Aug 28, 2009
harlan301
  • 205 Answers
SOURCE: starter cable housing assembly
you need the model type and code off the engine only in order to find that part. that is also a murrey
Posted on Oct 11, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a yard machine 5.75hp self-propelled mower won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 02, 2010
justinbur167
  • 257 Answers
SOURCE: MTD Yardman 12A-449T402, 6hp, self-propelled.
Hello Spattee,
I understand that you are having a problem with you Yardman Lawn mower when you try to use the blade control handle it is not allowing your lawn mower to start. I have had this issue in the past and it required the cable to be replace as it was streching as you use the handle. The cables are not expensive and can be pruchased at most local lawn mower shops.
Thank you for choosing FixYa.com
Jusin
Posted on May 06, 2011
How do I connect throttle cable to throttle trigger?
Search for online manual, that has the diagram, showing the location the end of throttle cable at the trigger. You will have to take apart the handle assembly, to access the cable and trigger.
Nov 05, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Throttle cable assembly
The cable you are trying to replace is the OPC cable (engine brake cable), not a throttle cable like you are trying to fit. You need to take it back and get an OPC cable, which will have the correct end on it to fit into the bracket on the side of the engine.
May 19, 2013 | Garden
Parts on mower
Looks like the throttle assembly and carburetor assembly are missing. Go to searspartsdirect.com for a look at the entire lawn mower parts list and you can order whatever is missing.
May 10, 2013 | Garden
Zero Turn Lawn Mower shakes on full throttle
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 14, 2017 | John Deere EZtrak Z225 Zero-Turn Riding...
How to repair throttle cable on mower
You didn't state what the problem with the throttle cable was. Is it stuck in place, did it break off, did the handle break, etc.
Give some more details and I can probably help you. If you don't know the terms, that's fine, just describe it as best you can.
Jun 25, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
New mower, purchased May 2011. The self-propel drive has stopped working. I have looked at it but cannot see anything loose or ????
Look on top of your mower as well as underneath your mower. Check the belt for excessive wear. Check to see if anything came loose. Move up to the area that engages the drive assembly. Is the cable if so equipped loose or disconnected , is there a spring missing, or is the cable jammed so that it doesn't engage the drive unit. Check up to the handle, possibly the cable broke, or has disconnected in some way. Just because something is new this doesn't mean it can't break, or get thrown out of kilter. You will find your problem. GOOD LUCK.
Jul 13, 2011 | Toro Garden
Scott bonner reel mower. Throttle cable.
look up mower throttle cables on google or type in throttle assembly it should show you how it fits on they are all very similar
Jan 13, 2010 | Garden
Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Jul 03, 2009 | Oregon Scientific Oregon Fusion Blade For...
Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd 22" Yard Machine Push Mower Logo
57 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
