Question about Jensen Awm910 Rv Wall Mount Cd Player Am/fm Radio
WHY CAN'T i GET ANY am RADIO RECEPTION?
I can receive FM radio but no AM radio.
4 Suggested Answers
merle840
  • 113 Answers
SOURCE: not recieving fm radio stations
if you can get am stations the problem is in the radio's tuner if you cannot get am stations either your antenna is bad, if this helps you please give me a good rating if not please e-mail me at merle840@aol.com
respectfully, m.merle
Posted on Oct 17, 2008
SOURCE: Loss of reception in 2002 ford focus factory radio fm
Common fault but as others have suggested, check aerial plug. It does fall out, speed humps vibration,cause it to come out of it's socket.If not this, try a seperate aerial such as a piece of wire or a small screw driver blade in the hole. Press search and see if radio finds a station and locks on.If it does then you know you have an aerial problem and your radio unit is ok. Sadly, if no luck and no result then the only answer is to relpace the unit as it is not servicable.These can be found at some car breakers but take your car and make sure that you buy a tried and tested unit with its pin No. Typical costs are £30 with casette and £70 for cd player.
However because there are so many different types of socket and plug arrangments on these units and they all look alike , don't be tempted to part with any cash until you have got the correct one that fits your car and it works. If does and you have its pin, it will have to be entered to make it work and you have made a written note of it in your Ford hand book , then pay the man. Good luck From been there and have the tee shirt. J.R. Note. Halfords do a fitted alternative replacement for around £150 if no luck and you are prepared to spend that kund of money.
Posted on Feb 05, 2009
  • 4869 Answers
SOURCE: Why can't I receive AM or FM radio
check the aerial is plugged in properly at the back of the radio
Posted on Mar 12, 2011
2003 grand marquis radio am does not work
Does anyone broadcast AM radio any more?
If you know you have a good AM station in your area, and you can verify its frequency, and your radio can't receive it but CAN receive FM stations... then that radio just isn't going to get AM. It's probably not worth fixing.
Aug 07, 2014 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
Apr 11, 2012 | 2008 Toyota Avalon
All of a sudden I have NO FM radio reception in my 1999 Jeep
If you still have good strong AM reception, chances are that the FM receiver portion of your radio has failed. Radio repairs are usually as or more expensive than replacing with an aftermarket unit. You can either find a direct factory replacement in a scrapyard or just buy an aftermarket radio (with an adapter harness) and install it.
May 27, 2010 | 1999 Jeep Grand Cherokee
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Radio reception
Say goodbye to this unit if FM matters to you
Mar 11, 2009 | Kenwood DPX-440
WHY CAN'T I GET AM RADIO RECEPTION - ONLY FM??
You need a seperate AM antena for your AM radio to work. If you look on the back of the system where the FM antenna is connected you will see a AM hole for an antenna. I had same problem hope it helps!
Oct 20, 2008 | Bose 3·2·1 II System
AM Reception
what kind of car are you driving. on some cars the antenna need to be extended in order to recieve am reception.
May 27, 2008 | Kenwood KDC-222 CD Player
Radio reception
Use a dedicated FM T-strip antenna avialable from Radio Shack or even Wal-Mart
May 01, 2008 | Audio Players & Recorders
Jensen Awm910 Rv Wall Mount Cd Player Am/fm Radio Logo
21 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
