Question about Singer 2250 Tradition
Serenade My upwinded bobbin on a totally new machina, was stucked -so I could lift the hole machine!Had put the stick to the left and followed all instructions. Why so small chinese bobbins? I want them with 1mm bigger hole.Or metallic. Now replaced the machine,but what to do IF the bobbin gets stuck upon the machine again?!I can never start sewing! Desperat.
  • 130 Answers
Personally regret to hear a kind of problem that you have on the machine, however the other customers are enjoying and benefited from it for one reason they were given demonstration before/upon purchasing the 2250. If your new machine does not include a demo cd, I suggest you visit singer site thru google "singer 2250 sewing machine" and you may be able to download the video on how to use the machine. Hope that can be useful.
Posted on Jul 25, 2013
Testimonial: "U regret U Heard my complaint??? Why bother answer then...?! I bought the german Singer machine in German company Lidl in Malta. Got the Swedish instructions I needed and went through every detail. Took it slowly 1st and a bit faster to wind it and not to the full bobbin. Moved the stick to left and bobbin was stucked! I tell U it's the plastic Chinese bobbins that cant take the winding, because I actually winded off the thread by hand and suddenly the bobbin just went off!! SO obviously the bobbin shrinks of pressure/heatand it should B a metallic one as in the good Days.... Thankx GB"
SOURCE: Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Posted on Apr 05, 2008
  • 323 Answers
SOURCE: bobbin case problems with machine,
First, rethread the machine and be sure the thread passes through the take up lever. If it still does the same thing, remove the needle plate to access and remove the bobbin case. Check the bobbin case for burrs, scratches or any rough spots. If you find one it needs to be buffed with an emery stick or sharpening stone until it is smooth and then buffed with some steel wool. Clean out any lint you see and reinstall the parts.
sewman7
Posted on Jun 27, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: viking sewing machine 545 bobbin stuck on rewind
Most machines you slide the bobbin winder to the right to wind and then back to the left when your done to remove. Just making sure.... you did move it back to the left?
Posted on Jul 28, 2009
  • 1116 Answers
SOURCE: The bobbin thread is sewing loose stitches and
Always have the presser foot up when you thead any sewing machine.
Make sure the flat side of the needle shaft is facing to the back of the machine.
Don't do anything to the bobbin tension. Set the top thread tension to what is recommended by the mfg.
Make sure the thread from the bobbin is feeding from the bobbin in the correct direction and through the correct guides.
After inserting the bobbin and threading the machine, lower the needle (hold on to the thread tail) and then raise it by turning the hand wheel by hand to pull up the bobbin thread.
Gently pull the two threads under the presser foot and to the back of the sewing machine before you begin to sew.
Posted on Feb 19, 2010
How to thread bobbin on Singer Serenade 30
The owner's manual should have instructions. Otherwise, search the internet for videos/tutorials for using your machine, ie:
Inserting the bobbin on Singer sewing machine
How to set up singer sewing machine MP4
Machines vary on how the bobbin is installed. A lot of Singers have a drop-in bobbin, but others actually have a removable bobbin case. Just search until you find one that is similar to yours.
Feb 14, 2016 | Singer Sewing Machines
For the dressmaker II, the first bobbin, I got through step 1-5 but where the does step 6 go BECUZ that's really trippin me, PLS tell me. And the instruction is not clear at all, I don't understand it
Hi Vicky, I hope this helps you:
1. Remove the slide cover plate by sliding it toward you, and lift
up the bobbin and the bobbin case from the machine.
2. Put the bobbin pin into the hole on top of the hand wheel and
place an empty bobbin on the bobbin pin (spindle).
3. Lift the large spool pin from the back of the machine and
place the spool of thread on the large spool pin.
4. Place the bobbin winder tension clip into the hole in the back
of the machine.
5. Pull the thread to the left and pass it through the bobbin
winder tension disc.
6. Insert the thread through the hole in the bobbin from the inside
out and leave about 3" of thread out. (ensure that the hole on the bobbin is facing upwards)
7. Hold the end of the thread and start the machine, either by
pressing on the start button or the foot control. After the
bobbin winds a few turns, stop the machine and cut the thread
close to the bobbin. (Cut the thread end that is protruding from the hole at the top of the bobbin).
8. Start the machine again and continue winding until the bobbin
is full or the quantity of thread is enough for your needs.
9. Stop the machine and cut the thread. Remove the bobbin from
the bobbin pin.
10.Take out the bobbin pin from the hand wheel and push back
the large spool pin into the slot in the back of the machine.
Good luck :)
Jun 21, 2015 | Euro-Pro Dressmaker 998B
Bobbin stuck in case - forgot to use the bobbin hook cover
take a small screw driver and gently lift an edge of the bobbin to lift it out
Mar 29, 2014 | Sewing Machines
Elna 6200 stuck in bobbin mode but sticking
Is the bobbin winder spindle on top of machine pushed over to the right in winding position? Move it back to left to change back to sewing mode.
Nov 30, 2013 | Elna Sewing Machines
Spare bobbin for singer serenade 30
try these sites and call or email them about the part you need
sewvacdoctor.com
a1sewingmachines.com
sewingpartsonline.com
Feb 22, 2013 | Singer Sewing Machines
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    Fabric stuck in hole where bobbin is underneath
    Turn off the machine and remove the needle.
    Lift the presser foot and remove the inner hoop and then the rest of the hoop.
    Move the fabric to one side and cut the threads with a seam ripper.
    Open the needle plate.
    Remove the bobbin and bobbin case.
    Clean away any thread or lint in this area.
    You should repeat the last three steps routinely as lint and thread snips can accumulate in these area and cause mis-stitching.
    Replace the bobbin case, bobbin and needle plate.
    Use a new needle.
    Jun 29, 2009 | Simplicity SE3 Computerized Sewing Machine
    How do you thread a kenmore sewing machine I can't figure out how to thread the bobbin for kenmore machine 1385.15343600.  I am a beginner, so I will need pretty detailed instructions. Thanks! Jenny
    Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
    Mar 05, 2009 | Kenmore 15343
    Singer 2250 Tradition Logo
    57 people viewed this question
    Top Singer Sewing Machines Experts
    Tally Girl
    Tally Girl
    mystery_soul
    Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
