Question about Onan Cummins 2.8 KV-FA/6050 RV QG 2800 EVAP 2800K C.A.R.B Compliant Ga
Onan 2800 generator sops when a/c is turn on
Onan 2800. runs find until a/c is turn on gen stops a/c is only then connected
    Prodigy:
    An expert who has answered 500 questions.
  • Onan Expert
  • 573 Answers
While you didn't indicate the btus of the HVAC I assume it worked before? What you are describing sounds like the engine isn't making horsepwer. A 2800 is a small unit that a HVAC and some lights is about all it can stand. The HVAC takes about 6 x current to start it, than it does to run it. If this inrush is high and the generator engine isn't producing full HP then it will shut off and die on under frequency. I would recommend having and engine leakdown test done (not a compression test, as that doesn't tell the whole story. This will ensure all valves and rings are mechanincally in good shape, then try a basix tune up, plugs filters etc.
Posted on Nov 14, 2013
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Gen starts then shuts down
Check rotor skip rings for cleanliness, rotor brushes. Stator resistance, rotor resistance. If ok then change control board
Apr 30, 2014 | Onan MicroLite 2500 & 2800 LP Gas...
My Onan 2500 Microlite LP starts when cold, but soon quits until it gets cold again. I think that the fuel inlet valve needs and adjustment. How is this done?
I would not adjust it, I would say the unit has sat and carb is gummed up. Flush with sea foam and run for as long as you can under heavy load
Oct 08, 2013 | Onan MicroLite 2500 & 2800 LP Gas...
My onan 2.8 gen. starts but quits when i let off the starter button, what can i do to fix it
maybe old gas or dirty carburetor first replace the gas if nothing happen open your carb and clean the pilot of the carb its one small screw w/holes inside most times get clog
Apr 14, 2013 | Onan Cummins 2.8 KVD-2090 RV QG 2800 RM...
I have a onan 2.8kvd rv gen. replaced the pcd and it still does the same thing push the starter button in and hold to keep running
You need to make sure you have voltage from the stator windings, this feeds abck to the control board. Have the rotor and stator checked, and brushes and skip rings
Apr 01, 2013 | Onan Cummins 2.8 KVD-2090 RV QG 2800 RM...
Have Onan 3.6 KY propane gen that will not keep running. Runs only as long as start switch is pushed. Then stops immediately after release. Fault code is 15 (underfrequency) and suggests removing heavy...
I am not familiar with your peice of equipment but from your description of the fault being Under Frequency it appears that generator governor is out of adjustment or the governor spring has brcome weak or broken and not allowing the engine to run at the correct speed to produce an output frequency within the allowable tolerance. Governor linkage could also be binding and not moving smoothly to respond properly to engine load conditions. Thoroughly check governor and throttle linkage for free and smooth operation and full range of movement.
Another cause could be that the engine is not getting sufficient fuel causing the governor to have the throttle wide open to try to get engine to run at its correctly governed speed but unable to do so because the engine is not developing enough horse power.
Jan 10, 2011 | Watts Onan Portable Generator - 4000 ,...
I have an onan 2800 gen that will not charge
If the govenor didn't work that means that you placed the linkage on the carberator the wrong way. This will cause the genset to overspeed and possibly stop the genset from creating voltage. If the genset does not create voltage then you won't have a charger. Fix the linkage first by looking to make sure that the throttle plate is closed before starting genset. Once you start the genset check for voltage.
Apr 12, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan Cummins 2.8 KV-FA/6050 RV QG 2800 EVAP 2800K C.A.R.B Compliant Ga Logo
176 people viewed this question
Top Onan Electrical Supplies Experts
Lawrence Oravetz
Jeff Hogancamp
Jeff Hogancamp
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
