Question about Bush Televison & Video
Bush lcd40883f1080p light flashes once then pause then flash won turn on
SOURCE: Power light flashing once
My problem turned out to be the D board. I purchased one on Ebay for $100, replaced myself. The service technician charged me $90 to come out and tell me the problem then wanted $700 to replace the board.
Posted on Dec 04, 2007
  • 3 Answers
SOURCE: Zebra S4M prints one label then goes to flashing pause light.
most likely it is a printer driver issue. There's 2 drivers, one for 200dpi and one for 300dpi. Use the one for 200dpi. It could also be the label setting is incorrect. Try running a calibration.
Posted on Jan 27, 2009
Blines
SOURCE: bush lcd tv turned itself off won't come back on
My Olevia LCD TV did the same thing. I turned off the back power switch and pulled the power cord as well. Left off for a couple of minutes and then re-connected cord and turned on main switch. I then turned on the front power switch and it come on just fine. These new sets have computer-like guts so you have to re-boot them sometimes. I hope this works for you.
Posted on May 08, 2009
  • 4044 Answers
SOURCE: Check engine light is on check engine light
Take the vehicle to Auto Zone, advanced Auto parts or o'Rieley's Auto parts and ask them to use their scanner to read the stored Code from the ECM for you.
Posted on Jul 19, 2010
eagle338
  • 4889 Answers
SOURCE: Toshiba 55ux600u Powers on,
From what I have seen the 3 blinks error code most toshiba tvs are caused by a faulty tuner software. You can try downloading the firmware from the link below and updating it.
http://cdgenp01.csd.toshiba.com/content/support/downloads/UX600U_001.exe
Update instructions are given here. Even though it does not turn on normally, it should be able to turn on for a firmware update. So copy the files on to a USB drive(less than 2GB capacity only) and insert it into the USB port of the tv. Then power it on and follow the instructions below
http://cdgenp01.csd.toshiba.com/content/support/downloads/Installation_Instruction_UX600U.pdf
If for any reason the tv still refuses to come on, even for the update, I am afraid you are gonna have to let a toshiba tech do it for you using "special tools". I hope that wont be necessary though.
Good luck.
Sai.
Posted on Feb 04, 2011
Bush lcd40883f1080p
What input do you feeds to this TV?
May 01, 2013 | Televison & Video
I HAVE A BUSH LED22982DVDFHDS THAT WON'T TURN ON STAND BY LIGHT KEEPS FLASHING
Flashing of standby light are fault indications, technically called blinking codes. From the number of flashes that occur at one time switch ON, you can get an idea about the faulty circuit section inside it. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Blinking codes to many brand TVs are described in detail.
Apr 21, 2013 | Bush Televison & Video
Blinking codes for bush lcd40883f1080p
Check this link for more detail about the blinking codes. These blinking are fault indication.
Feb 15, 2013 | Televison & Video
Bush lcd40883f1080p on stand bye blue flashing led
How many times do this light blinks at a time of switch on? Count it. These blinks are fault indications. From these blinks, you can determine about which section inside it is faulty. It will make fault location easy. Count it, and check this site for more details about these blinking codes.
Feb 10, 2013 | Televison & Video
My bush tv won't stop flashing
The tv need service. Contact any experienced service technician.
May 07, 2012 | Bush 1433GRN2 14" TV
Engine stops while driving,will not start or stay running for hours,only to die again in short time replaced fuiel pump pcv valve,fuel filter
Do not replace any further components until you have your On-board diagnostic (OBD2) codes read.
Your vehicle is fitted with a sophisticated OBD computer which monitors the performance of all engine emmission sensors and components.
By jumping pins 5 & 6 of your datalink connector (DLC connector located under dash, above driver's knee), your Engine Check light will flash the codes present stored in memory.
  1. Run the engine until it reaches operating temperature, then turn engine OFF.
  2. Using a thin jumper wire (speaker wire will do), join pins 5 & 6 (note this connector may be upside down).
  3. Turn ignition key to ON (do not run engine) - the Engine Check light should start flashing.
  4. The 1st group of flashes is the 1st digit of the code; (short pause), 2nd group of flashes is the 2nd digit of the code (short pause) and so on. Note: codes will be separated by a long pause. E.g. Flash, Flash, Flash (short pause), Flash, Flash (short pause); Flash, Flash, Flash denotes: Code 323 etc
  5. Codes will usually repeat - turn key to OFF, once codes have been correctly read.
If the above procedure works for you, please post your codes on here and one of us will assist you with further diagnosis.
Cheers,
Aug 27, 2011 | 1997 Chevrolet Camaro
How do u diganose engine codes on a 1985 dodge 600 se 2.2
If you have an obd reader, there is a wire under the hood on the passenger side where obd connector can be plugged
Aug 26, 2010 | 1985 Dodge 600
Jul 14, 2010 | Cars & Trucks
Service engine soon light on a 1996 caravan sport
The codes can be retrieved by turning your ignition switch on and off three time quickly and watch your service engine light. It will flash once pause then flash twice then it will begin to give any fault codes that have been stored. It will flash once or twice then pause then flash in concession again then pause and start another code if any. When you have retrieved all the codes available it will flash 5 times pause then flash 5 times which means it has finished. There are several sites on the net that will explain what each code stands for and which circuit needs your attention.
Sep 05, 2009 | 1996 Dodge Caravan
Televison & Video Logo
73 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
