Konica minolta c450 error c2550 - Office Equipment & Supplies
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Posted on May 27, 2008
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
  • 158 Answers
SOURCE: KONICA Minolta c450 in Windows Vista
go to the printers and faxes page and in the driver properties click on printing preferences click on authentcation/account track and you should be able to enter you name and password from there unless you may have to be logged on as the administrator on your computer to make these changes
Posted on Oct 23, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Problem with the Konica Minolta
This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
Good Luck and Thank You for using Fixya.
Wheatland Services
Posted on Feb 16, 2011
Error p5 in konica minolta c450
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed..
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
Error p 5 konica milnolta bizhub c450
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
P 5 error in konica milolta c450
Sir/Mam
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed.. recommended a tech do this unless you known what you are doing.
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Minolta C450 fault code C-2656
konica minolta bizhub c450 error code c2656
Feb 09, 2013 | Konica Minolta Office Equipment & Supplies
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
165 people viewed this question
k24674
