Question about Nokia C5 Cell Phone
Jalur sim card sgh c450 - Nokia C5 Cell Phone
How do I put all my num bers onto my sim
goto contacts and copy contacts r move contacts option
and phone 2 sim r sim 2 phone optionn ll b thr.
choose wht ever u want simple
Dec 05, 2013 | Samsung SGH C450 Cell Phone
Sim lock
You can remove the sim lock from your phone using unlock code.You can get the unlock code for your Samsung SGH-C450 phone from your Network service provider or any third party online Vendors like SimpleUnlocking.com here they ask your country,Network name to which it is locked,IMEI number of your phone.Then they deliver unlock code to you through mail. And you can get free unlocking instructions from the site MobileUnlockGuide.com
Jul 16, 2013 | Samsung SGH C450 Cell Phone
Cod puk for SGH C450
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
Sep 25, 2012 | Samsung SGH C450 Cell Phone
Minta jalur skema sim card samsung SGH-E250
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Jan 18, 2011 | O2 Samsung SGH-E250 Cellular Phone
Master password samsung sgh c450
My Dear Brother:
Esta es una lista de códigos que te permite liberar tu celular Samsung para los modelos S500 / P400 / E500 / E700 / X100 / X600 / E100 SGH-600 / SGH-2100, se dejan a continuación detalladamente los pasos a seguir y si debe o no usarse con una SIM.
Deben recordar que este código borra sus archivos configurados en WAP y MMS. Pero que dependiendo de la empresa que tengan pueden volver a configurarlos fácilmente.
Para S500 / P400 / E500 / E700 / X100 / X600 / E100 el código es : *2767*3855# y debe tener dentro una SIM que este aceptada.
Si falla, teclea *2767*688# o #*7337#
Para SGH-600 / SGH-2100 el código es *2767*3855# y tiene que tener dentro una SIM que este aceptada.
Si el código no funciona sigue estos pasos para dejarlo tal cual como estaba: Inserta una tarjeta SIM que el telefono no acepte luego si aparece Wrong Card, pon #9998*3323#, despúes teclea exit y selecciona el numero 7. El telefono se reiniciará, Luego de esto la SIM debería funcionar.
Luego para ingresar otra SIM desbloqueada pulsa *0141# y apaga el telefono e inserta la otra SIM, Si necesitas un último código para ingresar marca 00000000.
Vía: http://universocelular.com/2008/02/11/liberar-celulares-samsung-sin-cables/
Thanks
Aug 13, 2010 | Samsung SGH-C425 Cellular Phone
Sim lock code samsung sgh c450
You mean you want to unlock your phone?Try this code..
1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile
then enter...
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
Jan 24, 2010 | Samsung SGH-C425 Cellular Phone
My samsung sgh-c450 diplay limitid service
It means that the sim card is not detecing any network and your phone is out of your provider's network try switching it off and on, take out the sim and insert again, or if possible try your sim in some other phone or your phone with other sim
Let me know if this helps
Regards
Nov 30, 2009 | Cell Phones
Master password for samsung SGH C450
Jul 23, 2009 | Samsung SGH-C425 Cellular Phone
Pin code request when turning phone on
turn it off and get out the sim or get the box that it came in and then thell be a card ia credit card itll tell you the PIN. dont know how to unlock im trying to figure that out to. type in the pin and go to the langue settings and select english.
Dec 26, 2008 | Samsung SGH-C425 Cellular Phone
hey everyone.
i have read a couple of threads i have found on the internet and i have tested this on my samsung sgh-c450 locked to telstra. no computer is needed (or cable). i hope this helps anyone with a samsung. WARNING: ALL CONTACTS AND OTHER SETTINGS MAY BE LOST DURING THIS PROCESS!!!
Method:
Before you start, make sure the battery is charged and all security codes or PIN codes or watever are disabled so we dont have any code prompts interfering with this method.
1. Turn off the mobile phone.
2. Insert a "Non-accepted" SIM card (sim card that wont work) half way in so that when you turn on the phone, it still says "Insert SIM".
3. Turn on the phone.
4. Aant. Harry----- punt 4 is vervallen ivm met het verwijderen van de emei-code.
5. Once reset has completed, the phone will still say "Insert SIM". This is where you need to push the sim card all the way in. You can use a paperclip or a tiny object to push it in if you have difficulty. IT IS IMPORTANT THAT THE PHONE REMAINS ON AT THIS STAGE (TRY NOT TO LET BATTERY FALL OUT) IF BATTERY FALLS OUT, DO NOT PANIC, JUST START FROM STEP 2 AGAIN.
6. Enter the following code and wait patiently for phone to reset:
*2767*3855#
7. After reset is completed, SIM should work and also the reception. Don't get excited, its not unlocked yet.
8. Now we want to make it permanent. First check what locks need to be deactivated with the following code:
*#7465625#
Aantekening Harry: Om de codes in te voeren moet je een keer op de rode toets (naast C) drukken, zodat je in het beginscherm komt. Dan kun je codes intoetsen. Dus geen codes intoetsen als je in het keuzemenu zit.
a)
If Network Lock is "Active", put in the following code:
Message should be "Network Lock has been personalised" or similar.
Then:
Message should be "Network Lock deactivated" or similar.
b)
If Subset Lock is "Active", put in the following code:
*7465625*782*00000000*00000000#
Message should be "Subset Lock has been personalised" or similar.
Then:
#7465625*782*00000000#
Message should be "Subset Lock deactivated" or similar.
c)
If SP Lock is "Active", put in the following code:
*7465625*77*00000000*00000000#
Message should be "SP Lock has been personalised" or similar.
Then:
#7465625*77*00000000#
Message should be "SP Lock deactivated" or similar.
d)
If CP Lock is "Active", put in the following code:
*7465625*27*00000000*00000000#
Message should be "CP Lock has been personalised" or similar.
Then:
#7465625*27*00000000#
Message should be "CP Lock deactivated" or similar.
e)
If SIM Lock is "Active", put in the following code:
*7465625*746*00000000*00000000#
Message should be "SIM Lock has been personalised" or similar.
Then:
#7465625*746*00000000#
Message should be "SIM Lock deactivated" or similar.
"a)" is the common one that usually is the only one need to be done but if other locks are active, i think its best to disable them now while you have the chance.
Now you have unlocked your phone!
Tested on:
SGH-C450
Please test this!
Thank You.
Sep 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
Nokia C5 Cell Phone Logo
19 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
