Question about Refrigerators
Whirlpool side by side refrigerator not cooling
Freezer is fine the refrigrator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
  • 2 more comments
  • Anonymous Dec 28, 2007
    freezer is not freezing and refigerator is not producing cold air. Refrigerator temp. is an average of 60 degrees.
  • bobbygunn Sep 25, 2008
    50 degrees in the refrigerator. Freezer, freon cycle, fans, are all working fine. The only things left are a clock type mechanism and the thermostat for the refrigerator that has a tube attached to its back that wraps around where the cold air comes in from the freezer side. It must be one of these two things, but what do they do?
  • Tom Frazee Nov 14, 2008
    I have a GE Model # TPH21 PRSM WW refrigerator that is doing the same thing. The freezer is cooling fine at 10 degrees. But the reefer is a warm 50 degrees. The evap fan seems to be working ok but I did notice that the baffle between the two is closed. What do I do? I need some cooling quick. Please advise
  • Anonymous Dec 02, 2008
    i have Goldstar GR202DDP Model. it is running some days, Then the compressor getting hot, whole system automatic stop. any one help tosolve this problem.
  • 53 Answers
First off open reefer door put your hand on the diffuser at top left corner where the air comes in if nothing try to open door if air comes in the return vent is clogged if still nothing try to check if the diffuser is opening up. also make sure there is no ice buildup on evap coils.
Posted on Nov 04, 2009
Check t/stat or temprature controler and check the gasket for air leak.
thanks
Posted on Jan 05, 2009
  • 63 Answers
It might have a defrost problem check timer heaters and defrost limiter if it has a build up of ice in the freezer on back panel if not try turning the control for the food caompartment to let more cold into the food compartment
Posted on Aug 29, 2007
2 Suggested Answers
SOURCE:
huuum
  • 750 Answers
SOURCE: whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Posted on Oct 08, 2008
Get freezer to work?
Defrost system component(s) failure or a failed evaporator (cooling coil) fan motor failure. The fan motor should be located in the freezer section.
Sep 16, 2014 | GE Refrigerators
Top of the refrigerator is not cooling and the freezer portion is to cold
Main cooling happens in the freezer.
Since top (fridge part) not getting cooling the sensor in that part is continuously asking for cold. So the freezer get colder and colder.
Fridge part not cooling can be due to one of the many reasons.
Evaporator fan, Defrosting problem, Damper motor issues etc etc.
Sep 02, 2014 | Whirlpool Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
heatman101
Dec 21, 2010 | Refrigerators
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gs2shaxnl00 freezer working but not fridge not
The possibility is that the freezer fan is not working or the passage from the freezer to the refrigerator where the fan blows the cool air from the evaporator is blocked. Also if you say you manually defrost it could be that it is not self defrosting which can also cause this problem because the evaporator will build up ice and block the flow of the fan air
Jul 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kemore brand - freezer works fine, refrigerator not cold,
The fresh food side is cooled by the freezer side through a duct between the two. It will have a small door that opens or closes depending on how cool you want the fresh food side. The door opens more as you adjust the temp for the fresh food side colder. If the duct is blocked in any way, then it would be like setting the temp setting for the fresh food side warmer and warmer. The freezer would be cold and the fresh food side would be warm. Set the temp to midway. Check for any obstructions to this duct. The evaporator fan is what moves the air to the fresh food side.. If the evaporator fan is not working, this could vary well is the problem. You may have to check the evaporator coil to see if it is frosted up enough to restrict air flow over the evaporator and to the fresh food side. If this helps you find your problem, please rate me. If there is anything else I can help you with, please ask. I am here to help you.
Nov 14, 2008 | Refrigerators
Hello danielscynt,
Welcome to Fixya,
Huuum
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
656 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
