Question about Dryers
Bosch exxcel condenser dryer
What is the procedure for removing the top front control panel?
  • Dryers Master
  • 16,010 Answers
The top of the unit pops off, you have to pry it up. Be careful not to damage the paint. Then when it is off, you can see the screws that hold the front control panel on.
Posted on Jul 23, 2013
Bosch EXXCEL 7 1200 trips the RCD before even starting
Sounds like you keep the washing machine in an environment which is either damp or not well ventilated.if condensation or moisture finds it's way onto the main control panel of said machine it will cause short circuits which will then trigger the house protection circuits.quick solution is to gain access to the control panel by removing the top after disconnecting power supply.then using a hair dryer over the circuit board panel for about five minutes, reconnect power and keep hands away from any internals and try to repeat the problem.if it still trips it could be a faulty relay or that the main pcb has failed.have you recently experienced local thunderstorms as this is another possible reason for damage to pcbs.
Jul 06, 2015 | Washing Machines
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
I cant figure out how to change the light bulb on my Bosch WTL 5410 Condensation dryer. The bulb cover is at 12:00 inside the front cover (hard to crane your head around to see up there). I can't feel or...
You need to go through the top panel with the switches to access the bulb. First remove the screws that hold the top to the dryer. (There are a series of tabs with the screws.) Next, use a flat blade screw driver to push down and pull out the plastic tabs along top of the front panel. Pull the top of the front panel back. Now look for some plastic tubes. Stick a screw driver down into the machine and pry the tubes up at the bottom. Then you can access the light bulb and its socket.
I hope this helps.
Oct 01, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch 1200 classixx trips fuse unit
Possible that the program controller unit is faulty, it is possible that the power supply is short and so trips the fuse.
Remove the power panel and check for shorting, if so the program controller must be replaced.
Jun 27, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
Do not have operating instrutions for bosch exxcel washer dryer
see if you can go on line and download the manual fron the maker of your machine if you cannot find go to Google and type in what you need
Jan 07, 2010 | Bosch Exxcel WVT 2850 Front Load Washer /...
Filter light flashing on bosch exxcel condenser, repeatedly.
This should help you find a manual.
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Dryers
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Exxcel
Check the drain pump. It may be jammed. Remove filter and try to turn impellar by hand . If not turning freely, replace pump or remove obstruction.
Oct 31, 2007 | Bosch Exxcel WVT 2850 Front Load Washer /...
Dryers Logo
80 people viewed this question
Top Dryers Experts
