Question about Canon IR-1022 Copier
Canon ir 1020 showing jam error
My canon copier is showing jam error. i removed the jammed paper, opened the left cover but it is still showing the error. what should i do?
  • 28 Answers
SOURCE: CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Posted on Feb 28, 2008
Cogz
  • 1326 Answers
SOURCE: PAPER JAM
Open the front door and do you have a sorter on it? If so, you need to move it away. The finsher has a bracket and right under the bracket there is a handle pull the handle up and find you will see your jamed paper. Also, look at the duplex area under the transfer unit. It has a green handle lift it up and maybe find a jam there. You may have found it by now
Posted on Jul 18, 2008
solofixya
  • 34 Answers
SOURCE: Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Posted on Nov 10, 2008
FixinFax
  • 3085 Answers
SOURCE: canon ir 2016 is displaying
there is a black switch knocked out of it's holder.
Posted on Feb 14, 2010
  • 165 Answers
SOURCE: paper jam/open left / drawer cover canon ir2020
check the route sheet to the oven tray.
check all sensors on the route, as I remember are three in number.
check to be all clean and properly positioned
http://uploading.com/files/48b21612/...52CiR2016.pdf/
from this link you can download the service manual.
Posted on Mar 09, 2011
How can i fix paper jam, close left cover or drawer cover ir 2016 canon
hi . be sure there is no paper jam inside the machine . turn off and on if problem persist maybe some of the flag sensors maybe stuck.
Mar 23, 2016 | Canon iR 2016i Black and White Copier
How do i fix power on paper jam on canon ir 3035 copier?
Probably one of the sensors on the papers way through the machine is out of position,or not working
Mar 05, 2015 | Canon Office Equipment & Supplies
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Canon ir 5000 showing paper jam in leht hand LCF but no paper at this point or any where else
two possibilities...
feed rollers are worn out... replace them...
or paper wadded up in lcf
or another possibility... bad sensor or dirty sensor...
Aug 13, 2011 | Office Equipment & Supplies
Canon ir 2270 having a problem of paper jam but it doesnt show any error code can you help me solve this problem. by Fredy Gabriel
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
Jun 08, 2011 | Canon imageRUNNER 2270 Copier
My copier was working just perfect.(canon ir 1270f)...and had a paper jam..removed and now its shows error code toner/drum crg..what could possibly the problem...please help me out with this
hello
remove the paper jam and close the front cover and unplug the power from the outlet and same at the back of the printer, wait for 5 minutes and plug it again. this will helps to clear the error code of the printer.
thank you
Mar 08, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Assembly
Mar 19, 2009 | Canon iR 2020i Laser Printer
I am receiving an error of canon ir 1210- rec.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Mar 15, 2009 | Canon imageRUNNER 1210 Copier
Canon IR-1022 Copier Logo
44 people viewed this question
old marine
old marine
