Access to clean the fan on a Pyrox Firestar LN 323 m
Hi, I have an old Pyrox Firestar LN 323 m and can see through the bottom grill to a filthy fan. How do I reach the fan? How much of the heater do I need to take apart? Also wondering if this could be causing a yellow pilot flame or is there an adjuster somewhere to make the pilot burn blue? I'd be very grateful for any help. Thanks, Fiona.
  • 41 Answers
SOURCE: yellow pilot on heater
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
chillmaster
  • 104 Answers
SOURCE: My therma gas heater will
You need to replace the thermocouple. This is a small metal rod that is positioned in such a manner that when the pilot light is burning, the flame is contacting the thermocouple. When heated by the flame, the thermocouple produces a very small amount of electricity that it sends to the gas valve. The valve then interperets the electricity as confirmation that the pilot is burning and it is safe to conitinue delivering gas. Thermocouples wear out and stop producing power. The gas valve thinks that the pilot has gone out and thus turns the gas off for safety.
Thank You,
Chillmaster
Please rate my solution Fix-Ya as I put alot of effort into the detail and accuracy of my solutions.
Posted on Jul 05, 2008
SOURCE: Require fan for pyrox lpg
THANK YOU FOR THE REPLY
NOT MUCH OF A PROBLEM WILL CONTACT YOU IF WE NEED TO FOLLOW UP.
Posted on Aug 20, 2008
SOURCE: Marvin Box Fan Cleaning
It has six phillips-head screws around the perimeter. Loosen all six screws and the halves separate. Be careful loosening the screw that holds the motor in place - I ended up stripping the head. If you can use a vice grip to get it started, that may help.
Posted on Nov 01, 2008
SOURCE: Pilot adjustment on Williams wall heater
The insert sounds like the cap covering the adjustment screw. Pin hole is for cap removal. Wondering why flame is so high?! Shouldn't have orange flame. If heater doesn't light with lower flame... thermocouple (thing that the flame heats up) may be bad.
Posted on Jan 03, 2009
How do I remove the grill to get to the fan blades to clean them?
There's usually a screw or a clip which locks the two halves of the grill together. You need to remove the screw or undo the clip. Then you should find that one half of the grill cage just lifts out of its locating lugs. Once you've got the cage open you have access to the fan impellor. This should be removable. Sometimes by undoing the locking screw or just by pulling it off. You can now get to all parts of the fan assembly to clean it. Here are some links to useful sites:
DIY Home Improvement Information DoItYourself com
YouTube
Breaking News and Opinion on The Huffington Post
Jul 25, 2015 | Dryers
How do you clean a Crofton tower fan?
Any tower fan is something of a pain to dis-assemble. Lots of screws and tricky plastic parts that snap together in various ways. So I don't take anyting apart on the fan itself. I use an air compressor with a blower nozzle to get the job done. As you blow the fine stream of air over the vents and into various areas at the top and bottom, watch out for dust blowback. As you blow into the center vents/grille, the fan blade will spin around, too. After you've blown out the dust, use a damp rag, along with an old paint brush to clean out the grooves in the vents and grille.
Apr 25, 2015 | Tower Dryers
How to clean fan blades on sunbeam humidifier model 1118
I picked up a Sunbeam Humidifier model 1118 for $7 (which was $7 too much) second hand. It wasn't until I got home that I noticed it was filthy-dirty inside...(dirtier than shown in the photos) the reservoir, the bottom tray, AND the fan chamber all needed major cleaning.
A quick Google search told me that the grill is "not removable", and the unit is "not user serviceable". Companies do this/say this for two reasons:
a) They want you to throw it away and buy a new one, landfills and plastic filling our oceans be darned
b) They want to protect themselves from lawsuits, should someone injure themselves servicing their product (or in this instance, cutting their fingers off on the fan blade).
Imagine if all of that design know-how was put into making the product serviceable, cleanable, and long-lasting, rather than ensuring it can't be opened or repaired by the average joe.
Me, I've opened and repaired enough gadgets to think differently.
You CAN remove the grille.
Carefully insert a series of flat-head screwdrivers between the grill and the body a few inches apart, wedging the grill edge away from the body.
There are slits in the body (see photos) that will allow you to get under the grill edge and pry it right out when enough of it has been detached from the anchoring groove.
But be gentle while you're doing it.
The Grille is plastic and flexible; it will bend, but if you use too much force you will damage either the grill or the body.
The photos also show how the grill is anchored to the body - via a groove in the grille edge.
You can put the grille back after cleaning the blades and fan chamber much the same way; pressing down, and if required: prying the side of the grill inwards with a flat head screwdriver.
Mine snapped right back into place with a bit of downward pressure.
e766f363-7859-4f48-aa12-957dce77dc74.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-2.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-3.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-4.jpgclean-fan-blades-sunbeam-humidifier-gt2v12ze2wx14lgcssczfxw0-1-5.jpg
Jan 22, 2012 | Sunbeam Humidifiers
I have a model HE424M 33Mj/h gas Pyrox Firestar gas heater. I have just cleaned it and now it does not start. The pilot light is ok as is the spark but as soon as I let go of the centre button tha whole...
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out.
Sep 22, 2010 | Heating & Cooling
How do I clean Hitachi Tower Fan Model CF26PH? There doesn't seem to be a manual online in English and it's filthy inside. Can I just pull off the grill?
The easiest way is to take an air compressor and blow out the dust internally first through all of the vents. Then just take a damp cloth with a water/soap mix or some cleaning product that can be used on the plastic and just wipe down the outside. I recommend using the air compressor outside. If you don't have an air compressor available to you, then the cans of compressed air will work too.
Let me know how this works out for you.
Benjamin
May 23, 2010 | Hitachi Vacuums
Cleaning icemaker/water dispenser in door of freezer-its filthy
Use a butter knife between the dispensor grill and the lower portion of the cover . Push down and slightly outward on both sides of the lower cover . Then lift upwards after the bottom portion is free . There are 2 plastic tabs holding this lower portion on .
Aug 23, 2009 | Refrigerators
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Compressor will not kick in
compressor start relay mounted on side of compressor.
Jun 09, 2009 | Whirlpool Refrigerators
Where is the grill???
coils can be located in front behind grill, in back behind bottom cover or running up back wall of fridge. usually not coil problem unless it is just filthy. check 2 c if fan in freezer and fan in back of fridge are running. sounds like defrost problem or freon issue.
Jul 02, 2008 | Refrigerators
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
