Question about Water Heaters
Carver cascade 2 water heater - Water Heaters
5 Suggested Answers
gary1121
  • 332 Answers
SOURCE: no water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
Posted on Jun 21, 2009
gary1121
  • 332 Answers
SOURCE: no stop tap. cold water coming through cold taps
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Posted on Jun 24, 2009
  • 70 Answers
SOURCE: Carver cascade 2 No water at all comes out of the
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Posted on Oct 06, 2009
Testimonial: "Confirmed my diagnosis. Any idea how to get it unblocked?"
  • 351 Answers
SOURCE: CARVER CASCADE 2
Hello .. when an electric water heater only gets warm, it is usually the thermostats. I would replace the thermostats, make notes where the wires are connected .. make sure after replacing that the back of the thermostat is flat against the metal of the tank.
Please Vote !!
Posted on May 14, 2010
My caravan carver heaters pressure relief vale keeps blowing any ideas please
Not familiar with that exact heater but if it is an electric heater with a top and bottom element this may be the problem. Electric water heaters usually heat water off the bottom element. If a lot of hot water is used then the top one kicks in through the temperature controls. In some cases if the bottom element burns out, it will try to heat everything with the top element. This sometimes causes the water in the top of the tank to actually get too hot and it opens the relief valve. So you may have a bottom element bad. Otherwise your relief vale may need replaced or you have a sticking temp control making it get too hot.
Apr 11, 2015 | Water Heaters
Carver cascade 2 No water at all comes out of the hot water outlet. The inlet non return valve has been changed & is working correctly.
Oct 06, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
CARVER CASCADE 2
Please Vote !!
Jul 05, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
No water coming out of carver cascade water heater
Jun 16, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Water pump does not work when i turn on hot water tap
Since the cold water works, the problem is not the pump. Look for a blockage or possibly a major leak in the hot water system. if you have a kitchen sink and bathroom sink, are both hot water outlets not working? Does the water heater have shut off valve , or is its drain still open from when you winterized it (and the water running out to the ground instead of to the faucet?
Apr 22, 2009 | Water Heaters
Black soot in my jacuzzi tub
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
Feb 27, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
GE Profile Smart Water Heater leaking at top/no hot water
could be pressure relife valve as well- you need to tell us where water is comig from exactly in order to solve
Nov 09, 2008 | Water Heaters
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
