Sensor dirty i need to clean a sensor! what should i do?
    Champion:
  • 241 Answers
What kind of sensor or machine name or
Posted on Jul 23, 2013
  • bupe Jul 24, 2013
    its a canon ir 1020 black and white copier
Photosmart C5280 error messsage
1 - disc encoded may be dirty, clean it.
2 - disc encoded sensor can also be dirty, clean it well.
3 - Check the connection of this sensor with the logic board.
4 - Check if the paper sensor is not obstructed or dirty, it can be with a small piece of paper.
Good luck
I wait feedback!
Apr 17, 2012 | HP Photosmart C5180 All-In-One InkJet...
2000 GMC Jimmy. OBD2 code P0171. Whats wrong?
system too lean(bank 1). the maff sensor may be dirty or bad. to clean it , remove from vehicle and go to any auto parts store and buy a can of maff sensor spray. be very carefull not to touch inside of sensor, the best way to do it is to place on a clean rag and then clean it. put back on car when dry. this usually does the trick. Inspect all vacuum lines and the vacuum line from pcv valve. also make sure airfilter is clean and free of dust. if above does not solve problem, check fuel filter. hope this helps, follow directions on can to clean maff sensor.
Jul 20, 2010 | 2000 GMC Jimmy
I have 2002 chevy trailblazer lt the abs light stay on
Most likely one of your ABS sensors are dirty or the wire has corroded. Common for the sensors to get dirty since there magnetic and a simple cleaning will fix this. The ABS sensors are on each wheel on the inner side and can be cleaned with brake parts cleaner. If there was rust from the rotor or dirty that got in between the speed ring and sensor, you most likely have to replace the sensor.
Start with cleaning and inspecting the sensors, it my just be dirt build up and the sensor needing realignment which is a quick fix. After that and you still have the ABS light on, one of your sensors have gone bad. Go to Auto Zone and buy the brake parts cleaner and have them scan your trailblazer for which ABS component when bad to help address which sensor it is and yes they scan free of charge.
Thank you for using fixya.
Jun 29, 2010 | 2002 Chevrolet TrailBlazer
Where are the cam sensors (2) located on my 2005 chevy colorado
I have a 2005 and the things that go bad on it is when the sensor goes off then for the intake then where the butterfly is on the intake gets dirty and needs to be cleaned it is the venturi gets dirty and needs to be cleaned and if it is a cam crank then it is the cam actuator that needs fixed you can tell if you take it off and there a screen missing it is a good sign that it needs be replaced and it is on the left side of the engine you need to understand that if it gives you a code that tells you that it is a sensor that is telling you that what the sensor looks after is bad not the sensor
Apr 11, 2010 | 2005 Chevrolet Colorado
No longer gives out heat
your heating element is probably bad but this happens for some reasons. main reason clog in the vent you may need to get a chimney cleaning company to clean your dryer vent or do it yourself. another thing a dirty vent will do is trip the heat sensor. this heating sensor probably is the only thing broken if your vent is very dirty
Apr 09, 2010 | Dryers
My ford truck failed the smog test because bank 1 and 2 are to lean ( p0171 & p0174 )
possible solutions are, a dirty maf sensor. remove manifold air flow sensor and clean it with maf sensor cleaner. you can buy a can at any auto parts store to clean, take off and clean maf sensor, do not touch inside of sensor it is very fragil. when cleaning sensor be sure it is dry before installing it back on vehicle. also check for a vacuum hose leak downstream of maf sensor.make sure air filter is clean. this usually takes care of the problem. po171 and po174 are the same. you can use electrical cleaner to clean sensor also. also check for a dirty fuel filter and fuel pressure, if needbe.
Feb 11, 2010 | 1998 Ford Taurus
Ricoh 2045 error code SC350
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Dec 04, 2009 | Ricoh Aficio 450 Copier
How can i clean the small dirty black points on my photos?
You may need a technician (contact photo store or Canon)to physically clean your sensor. You can also do it yourself by purchasing a device such as found on this site http://www.visibledust.com/
Apr 04, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
Nov 01, 2007 | iRobot 5800 Scooba Vacuum
12 people viewed this question
jasbo
jasbo
