Question about Grilling
Hybrid grill gr3055 014684
Need new burners
I need a new burner for the E51 grill. It is a three-burner assembly, with spacing between burners about 8.25"
Parts for your grill are available from Electrolux 1-800-320-0859, as well Appliance Factory Parts
http://www.appliancefactoryparts.com/gasgrillparts/brands/electrolux/electrolux-burners.html
FYI - Frigidaire Grill Parts are interchangeable with Electrolux Grills.
Your Owner's Manual should list the part # for the burner you're looking for.
Hope this helped you and Happy Grilling!!
Jun 18, 2011 | Electrolux Icon E51LK60ESS (LP) Grill
I purchased a Hybrid grill @ Sam's Club and the
John, the best place to start is the manufacturer:
Rankam's BBQ Grills & Accessories
1322 Rankin Drive
Troy, MI 48083
888 837 1380
But, don't waist any time, as your grill only has a 90 day warranty.
May 16, 2011 | Grilling
Gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
May 15, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Hybrid GP won't turn on. Tried different outlets. There is a green light thats hidden in the bottom of the unit that does stay on. I push the power button and the unit does not turn on.
The front and rear plastic grills of the Hybrid GP trigger a power cut-off safety mechanism if either of the grills is not entirely in place. The grills have a tendency to slide down ever so slightly if bumped. The tiniest amount of slippage is enough to engage the power cut-off and it's not generally noticeable unless you know what to look for. If the Hybrid GP has no power at all, you may need to slide one or both of the grills upward just a hair. You should hear and feel a slight click when the grills are properly locked into place.
Feb 28, 2010 | Sharper Image Hybrid GP (SI724) Air...
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
Need model # for ge monogram grill. do not know where to look
Yes, the model and serial number is below the grill. My burners are also corroded. I have a natural gas with three burners, rotisarrie, smoker. It is also a 36". My # is ZGG36N31YSS. I have seen the YSS be CSS for propane grills. Hope this information helps :) If it does, I have found two sites with the burners; partsadvantage.com and appliance-parts-warehouse.com.
Run around $120 for one burner :(
Mar 26, 2009 | GE Monogram ZGG27N21CSS Grill
How do you chance the burners?
All you need to do is get the same length. Just remove the old ones by lifting them out after removing screws. Slide the new ones on the valves. NOTE: look at the air gaps on the air curtains on the old burners and try to match them to the new burners.
Jan 01, 2009 | Kenmore 490 sq. in. Cooking Area Gas Grill...
Need a Manual for Turbo STS Elite 4 burner BBQ - HELP!
if you havent already done it call bbq galore 214 696 0030
Sep 08, 2008 | Barbeques Galore Turbo Elite 4-Burner with...
Need new burners
Unfortunately this grill and parts are no longer being made. Uniflame has completely sold out of all spare parts. This grill was discontinued over 5 years ago.
May 25, 2008 | Uniflame FG2204C Grill
Grilling Logo
82 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
