Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Canon ir 1020 paper jammed..
Opened cover removed paper, also removed back cover and found no paper there. Still getting paper jam error.
2 Suggested Answers
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
How can i fix paper jam, close left cover or drawer cover ir 2016 canon
hi . be sure there is no paper jam inside the machine . turn off and on if problem persist maybe some of the flag sensors maybe stuck.
Mar 23, 2016 | Canon iR 2016i Black and White Copier
Paper jams on canon IR 1024A and solutions
My Hp was jamming and upon thorough inspection found a small corner of paper that had torn off and was causing the rest of the paper to jam.
Feb 12, 2015 | Canon IR1024 COPIER FOR 220 VOLTS
Piece of paper was struck in my canon IR 2420L.How to solve?Love to hear your answer.
Dear nima you have not mentioned the position of the jam ed paper. How ever you may check the try if found pull to wards you. next open the left cover by pressing a small window check the bottom if there is paper pull upward. next if paper jammed at fixing unit(heater unit) pull the lever (found at right side of the fixing unit) and pull the paper slowly to ward you. Close the door and reset. If no paper found clear all error using copier function.
thanks.
Jan 02, 2015 | Canon Office Equipment & Supplies
My copier was working just perfect.(canon ir 1270f)...and had a paper jam..removed and now its shows error code toner/drum crg..what could possibly the problem...please help me out with this
hello
remove the paper jam and close the front cover and unplug the power from the outlet and same at the back of the printer, wait for 5 minutes and plug it again. this will helps to clear the error code of the printer.
thank you
Mar 08, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
HPJ4680 says it has a paper jam. Opened all access doors, found no paper jam. Will even pick up a sheet of paper, feed it through the machine but then shows the same paper jam error message.
Hello and Welcome
If you are facing this error their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
After it if still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this will surely help you.
Don't forget to do Rating by Clicking on Four Thumbs which are given below to this solution if it is HELPFUL
Thanks
Mar 02, 2011 | HP J4680 Office Jet All-In-One Printer
My Canon MX340 printer says there is a paper jam .... there is no paper jam. I've opened the cover, the scan cover and checked in the back. There is no paper jam. i've tried resetting the printer by...
I had the same problem...after trying everything suggested on the forum. I had enough and decided to disassemble the printer. I removed the CAD and disconnected the wires and it solved the problem. No more paper jam error code on the screen. This probably includes that the CAD won't work anymore but I never used this anyway. So now I can print and scan like I used to.
Nov 06, 2010 | Canon PIXMA MX340 Wireless Office...
I am getting a System Error E021, what does this mean?
In my home office this error message came up, E021. I opened the Printer cover, closed it, unplugged and replugged and got a Paper Jam message. I removed the paper jam and did the cover/plug routine. Now I have a message CHECK PRINTER OPEN AND CLOSE COVER. But I can't find anything wrong! I have been searcing for an explanation of the error message online, but haven't found that either. my printer may be infested by aliens.
The best advice I can give is to reseat the various parts (drum and toners).
Thanks
Aug 17, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
112 people viewed this question
old marine
old marine
