Vidar p25 scanner - Office Equipment & Supplies
Can the vidar truscan p-88 4019 do color?
This scanner does black&white and gray-scale scanning but not color.
I hope this helps.
Aug 31, 2010 | VIDAR Systems VIDAR TruScan Select Pro
I don't have driver for truscan titan yet
hi,
hope this can help you for your truscan titan drivers update at the link below.
http://support.vidar.com/default.htm
Nov 28, 2008 | VIDAR Systems VIDAR TruScan Titan II
Software driver for vidar true scan select plus
Try this:
1. To obtain the driver, go to ftp://ftp.vidar.com/pub/sti drivers/ and
download "autocd.exe".
2. Run "autocd.exe" and the contents will be extracted to a folder.
3. In the Windows Control Panel, open the Device Manager (Control Panel->
System->Hardware Tab->Device Manager) and select the Driver tab within
the Vidar Scanners properties.
4. Click on "Update Driver" and browse to the STI folder (unpackaged from
autocd.exe).
May 09, 2008 | Office Equipment & Supplies
Select P36 not complete self diagnostic
I had same problem. Upgrading the firmware on the scanner fixed it all.
Mar 10, 2008 | VIDAR Systems SELECT P36
Minolta Dimage Scan Dual ll
Hello ! I try to use many difrent driver in difrent mod. eks:95,98,2000,xp
The best was 98,butt it still stops when the scanning starts.
Solution for my problem.......Vuescan from Hamrick.com
Mvh
Vidar
Norway
Feb 24, 2008 | Minolta Dimage Scan Dual II Film Scanner
Fluffs on my glases
Use a suction pad to lift the glass off of the magnetic plate and clean the underside.
Jan 25, 2008 | VIDAR Systems VIDAR TruScan Titan II Plus
Vidar select Pro Bulb? Blown out?
An E-mail to the makers web site will tell you whether parts are available for self fit or you need the expensive repair dude.
Nov 21, 2007 | VIDAR Systems VIDAR TruScan Select Pro
51 people viewed this question
k24674
jasbo
jasbo
