Question about Microsoft Office Access 2007 for PC
Hi, I have created a form in access 2007 called customer deliveries which is linked to a table called customer deliveries. On the form I have created a text box (called date delivered) which has a calculation as the control source based on another field in the form. After the calculation is done on the text box I want the value to be updated to the customer deliveries table in the relevant column of that table (date delivered). I have tried several types of insert into statements but have had no success in the table being updated. Can you please help me with this? Thanks Meagan
  • 58 Answers
SOURCE: Linking Calculated Totals from subforms to the main form.
Hi Raul from your description it is very unclear what you are trying to do. First we need to know what information is on the first form, second unless you are trying to do a subtotal of all orders in the subform there is no real need for you to create a subform. Now if you are trying to create a subtotal form for all records, you will have to set it up in the record source of that subform with group by: 1. Right click on an empty space on the subform 2. Click on properties 3. Choose your table(or query) which is the record source of the main form. 4. Select Payment and items(or what ever you are trying to calculate). 5. Press the group by button 6. In totals instead of group by choose sum. 7. Exit and save 8. Now when you will select the control source you will see "sumofpayment" etc... just select them for each textbox. 9. To create the third text box you will have to use the Expression builder and just do [textbox1]-[textbox2] * for some reason the nz function does not work in this case. I hope that helped you I will be able to give you a better answer if you give me more details... Let me know what happend Good luck Daniel
Posted on Sep 06, 2007
SOURCE: Access 2007 forms wizard
If you run a repair install of office 2003
Posted on Jan 20, 2009
  • 25 Answers
SOURCE: No available fields in form wizard
If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
Posted on Aug 22, 2009
SOURCE: Insert a calculated field named % Change in Value
If field A1 is the old value and A2 is the new value, then the formula for A3 (% change) is:=(A2-A1)/A1*100You can remove the *100 if you want to format the field to the Percent type.
Posted on Oct 11, 2011
  • 38 Answers
Assuming that the Original Value is in cell A1, and the New Value is in cell B1, then the formula for % Change pin Value is =(B1/A1)-1.Format the value in % style and you're done.Rgds,Scott
Posted on Nov 23, 2011
Having troube with my FOREIGN KEYs on two tables.
I suggest you visit this website you will get the solution, I tried and it worked.
Nov 25, 2013 | Computers & Internet
Dreamweaver Thought that Teaches You, to search a database with phpmysql...
OK, this should work... First of all, there is one great extension for DW & PHP ADOB object model that is free and great! Download it and install from its called PHAKT (NOT impakt, because its not free).
Install it and you will have another type of PHP ADOB document type.
Start project with PHP ADOB (not old PHP MYSQL).
Page 1
Create form that has come Editbox and one button. Name Edit box something like e.g. "Search" without quotes.
That form should have form action="results.php" and type set to POST NOT, Create Page 2 and name it results.php.
Create new recordset in dw like this
FROM table WHERE LIKE '%colname%' OR table.other.column LIKE '%colname%' ORDER BY table.tableid this means that we want to select ALL (*) records in table WHERE content of column is similar (Dav, will return Dave, David, Davidof...) to search keyword.
Next, in variables click + and add variable name colname default value set to % if you want to show all records if form is submited blank, or -1 if You want to show none if form is submited blank. Finaly for Run-time value type $HTTP_POST_VARS['search'] Runtime value is equal name of Edit box name you set up in first page...
Now, from bindings tab, select values and insert it on page, that You would like to show on page. Ill skip this part assuming You know how to format output and how to limit it but if you dont know ask in reply...
So now You have page with results. Test it and see if its working.
If it is, create page 3 and name it details.php. Now, select value from page that you want to link with details page and click on link. Select details.php page and click on parameters. For param name enter something like id since this should be PK in table and unique value, and for value click on lightning icon, and select primary key in your table. In live page link should be like details.php?id=<some_value>.
As for details page recordset it should look like
FROM table
WHERE = 'colname'
create vars as for page 2, but change Runtime to $HTTP_GET_VARS['id']
and format output on page. That should be it, but since im typing it in "realtime" maby i forgot something...
Home I did helped You.
on Jan 21, 2010 | Computers & Internet
I want to programaticaly modify an SQL statement in VB6
If I remember correctly you need to call ExecuteQuery or something similar otherwise it does not update the database.
Jun 16, 2009 | Microsoft Visual Basic Enterprise Edition...
Want to populate a form with data from a table, the Id number is keyed into the form and once it's matches with the Id in the table I want the other fields on the form to be populated with the data from...
Create a Form from the main table with a subform based on the other data you will want populated. You put the fields in the subform that you want populated from the main form. Go to the properties for the subform and select the data tab, In the data tab, select the Link Master Fields and choose the field you want linked. When you type the ID number in the main form, the other firlds you have in hte subform should populate from the data inthe table.
May 14, 2009 | Microsoft Access 2003 for PC
Feb 10, 2009 | Microsoft Office Professional 2007 Full...
I installed DB2 in my laptop . then i go to all programs->DBCOPY1(default)-> command line tools -> command editor then write down query to create a table but i cant build it it is showing CREATE TABLE...
Before you create a table you need to:-
1. create a database
2. create a username and password or use the admin generated userid
3. connect to the database
you can then create a table and use the database
Please post if you do not know how to do this and i'll give you some links
Dec 05, 2008 | IBM DB2 Connect Enterprise Edition for PC,...
Connectivity between HTML page and Ms-Access
Set MyConn = Server.CreateObject("ADODB.Connection")
MdbFilePath = Server.MapPath("sample.mdb")
MyConn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
SQL_query = "SELECT * FROM Friends"
Set RS = MyConn.Execute(SQL_query)
<LI><%=RS("Name")%>: <A HREF="<%=RS("Link")%>">Homepage</A>
Nov 11, 2008 | Microsoft Office Standard for PC
Wizard unable to create form
i had this problem and it was because a computer class was installing multiple kinds of access on one computer. they wanted to teach all of them, but are now screwing them all up. ha.
Nov 10, 2008 | Microsoft Office Professional 2007 Full...
Jun 04, 2008 | Microsoft Office Professional 2007 Full...
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
Microsoft Office Access 2007 for PC Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
