Question about HP Compaq 6715b Notebook
Don't have light on LCD screen
When I turn on the laptop everything is OK except for display. Display remains dark, but over time you can see the images on it. On the external monitor is OK picture. CCFL and inverter is OK. ADJ and ENA pin on the inverter and one is 0V. The power pin (6,7) is 19 V.
    Top Expert:
  • HP Master
  • 12,223 Answers
You can RUN the software diagnostic coming with the computer or download the s.diagnostic from your computer supplier.
However you must restar the computer HOLD the keys CTRL+f11 or f12 depend of your mark, and go to restore at factory default and try it.
If the problem persist, is time to go to the repair shop, control board defective or screen faulty.
God bless you
Posted on Jul 23, 2013
Testimonial: "Thank you, I try your solutin....."
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Jun 07, 2013 | Computers & Internet
My omnia 7 LCD abnormal display. The LCD takes time to light up and display nothing.
You may say the display back light is not bright!There is the image, but a dark?If that is so, said display lamp is not lit .Need for a period of time will gradually light up!This may be associated with an operating voltage, at the same time, the display of inverter would let check design does not reach the designated position!Somewhat similar to " light " the voltage is not enough is not lit!You can try, don't open other electrical appliances, the first open display, and then, again other equipment!If the screen is fuzzy, so, I think we should display inside the PCBA plate has a problem!USB Data Sync Cable
Sep 05, 2012 | Eforcity Samsung GT-i8700 Omnia 7...
My Acer Aspire 5551-2036 wont turn on blue light turns on screen remains black
Does it sound like the laptop booted up except the screen is black? Do you hear the fan running and the hard drive spinning? If so try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 06, 2012 | Computers & Internet
I have a CQ60-615DX and when I turn it on the screem is black, so what is the problem.
When you turned it on does it seem like the laptop booted up all the way except the screen is black? Do you hear the fan running, the hard drive spinning and everything seems to be ok except the screen is black?
Apr 23, 2012 | Compaq Computers & Internet
My Dell laptop turns on however the screen does not. The battery light keeps flashing. I charged it for 2 days straight and it did not work. Lights and everything else turns on except the screen. The...
Hi, what i would suggest is to use an external monitor and if you can get something on your external monitor, reseat the lcd cable or display cable refer to this website for instructions (http://support.dell.com/support/edocs/systems/latd620/en/SM/display.htm#wp1105347) - if still same - the lcd has got to be replaced.
Nov 10, 2010 | Dell Latitude D620 Notebook
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Feb 07, 2010 | Office Equipment & Supplies
No light from my replaced display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 28, 2009 | HP Pavilion dv5000t Notebook
Cant see anything diplayed on my computer MT3422
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 18, 2009 | Gateway MT3422 RTL Notebook
Display went dark
The backlighting is provided via the LCD inverter as you described.
Dec 08, 2008 | HP Pavilion dv1000 Notebook
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
HP Compaq 6715b Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
