Need to find engine number where is it
SOURCE: Where is engine Number Location for Toyota Corolla
if your looking for the engine details lift the hood of the car and there will be a sticker on the hood to the right about eye level it will have the details of the engine it should say something like 2.4L and then give details about emissions and the car......................... I hope this helps
SOURCE: 1996 toyota tarago is stalling on an irregular
The mechanic is most likely correct the vehicles have double intake as well as double exhaust valves which allows the motor to retain most of its power even if one of the valves burns out. However if an intake valve burns or fails there usually is a popping sound or misfire upon acceleration in this case you most likely have a burnt or worn exhaust valve, you have about six months to a year before the truck starts really misbehaving. Just address the side of the engine or head that has the burnt valve don't let them talk you into doing both cylinder heads you may go 250,000 to 300,00 miles before having to do a full valve job on the truck. These motors are fairly tough so just do the one head not both when the time comes.
SOURCE: location of fuel filter 87 toyota van
1987 Toyota Truck Van 4WD 2.2L FI 4cyl
The Fuel Filter is located front seating area, center, under engine cover,
passenger side of engine compartment, near
firewall, mounted in fuel line.
Hope helps with this (rated this) Good luck.
SOURCE: How do I replace the flex coupling on my 1996
undo all covers to allow acess to shaft undo all bolts holding flex coupler 6mm allen key + 12mm spanner undo the gaurd the shaft goes through remove all bolts, lever rear coupler apart, push rear of shaft towards passenger side of car, slide shaft out, refitt in opposite order, certain models toyota tells you that whole shaft required, for about 3,000 dollars . after market couplers available from hardy spicer, shaft will have to be removed first to know if 12mm or 14mm dowel into end of shaft
hope this helps
