Whirlpool wfs1273aw
The door open light is on even though door is shut, also reset button stuck in
  • 130 Answers
SOURCE: whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
Posted on May 03, 2009
  • 73 Answers
SOURCE: washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
Posted on May 23, 2009
sclarke7
  • 222 Answers
SOURCE: Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Posted on Jul 08, 2009
SOURCE: My Whirlpool washing machine WFS1273AW,
The same thing happened to me and it was because there were socks stuck where the drain pipe attaches to the machine. If you tip your machine on its side and pull the black pipe off from the bottom of the drum you can remove anything which is stuck. Then it just clips back on again with a metal clip.
Posted on Sep 04, 2010
  • 113 Answers
SOURCE: Whirlpool WFS1273AW Front loader The clean
Remove bottom panel. You should see a trap on the pump. Rotate cover ccw. Have pan ready to catch some water, or some towels.
Posted on Sep 28, 2010
I have tried resetting dominator garage doors as suggested on your website however it still keeps going back to obstruction light even though nothing obstucting door. Any ideas what next. Thanks
I have tried resetting dominator garage roller doors as suggested on your website however it still keeps going back to obstruction light flashing even though nothing obstucting door. Any ideas what next. Thanks
Mar 12, 2013 | Home Security
Whirlpool washing machine WFS1273AW manual
I have a whirlpool WFS 1273 AW front loader that gets stuck in the spin cycle. The timer counts down from 18 minutes to 17 minutes and starts to spin but before it gets to full speed the control panel lights all flash, go blank, and the. The timer resets to 18 minutes. I have cleaned he drain pump, removed the clothes and tried it when empty and it does the same thing. It does not appear out of balance.
Jan 04, 2012 | Whirlpool Washing Machines
My Whirlpool washing machine WFS1273AW, has been displaying "clean pump" and F02. I have cleaned the pump and even had a repair man change the pump. However the machine won't move beyond the wash cycle and...
Aug 31, 2010 | Washing Machines
I HAVE A 96 OLDS 88 AND THE INTERIOR LIGHT WILL NOT SHUT OFF AFTER YOU CLOSE THE DOORS? ANY HELP WILL DO. ALSO THERE IS A SMELL OF GAS AFTER THE CAR SITS?
There are 4 buttons for each door. These buttons must all be closed for the interior light(s) to go off. Open each door one by one and rapidly depress and release the buttons maybe 10-20 times each. I've seen this a million times, one button is stuck open even though the door is closed.
Bring the car to a good mechanic for gas related issues. Gas vapors explode, if the car is kept in a garage you have a real chance for an explosion.
Nov 27, 2009 | 1996 Oldsmobile Eighty Eight
Door Ajar message comes up even when all of the stores are shut. Interior Lights and Lights on side view mirrors stay on. Lights can be shut off but the Door Ajdar message remains on.
I have this same problem. A mechanic friend told me that basically the grease they use to grease the door latches cause a sensor to think the door is open. He said to buy something thtat will break up this stuck grease, but also has lubricating effects. I forgot what he told me to buy though.
Aug 07, 2009 | 2003 Mercury Mountaineer
I have a wfs1273aw and its "clean pump" light is on an will not finish wash what do i do?
It sounds like your "drain pump" is either blocked or seized. Does the washing machine have a coin trap or small door at the front? If so, then open it, unscrew the plunger behind the door, then check inside for any foreign objects/material. Tip: Using a torch helps a lot.
Jun 16, 2009 | Whirlpool GHW9150 Front Load Washer
Washing machines door open light is on, but door is shut
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
