Question about Acer Aspire 5315-2153 Notebook
Fan help need
I was told to take the battery out of my acer aspire 5315-2153 notebook and remove the 3 screws that hold the cover over the speakers and that is where the fan will be ?
SOURCE: Replacing RAM chip in a acer aspire 3000
I found the user manual at http://www.synapsenow.com/synapse/data/7117/documents/AS3000-5000_UG_ENG.pdf Page 63 of the acer user manual listed these steps for changing the memory: "1 Turn off the computer, unplug the AC adaptor (if connected) and remove the battery pack. Then turn the computer over to access its base. 2 Remove the screws from the memory cover; then lift up and remove the memory cover. 3 (a) Insert the memory module diagonally into the slot, then (b) gently press it down until it clicks into place. 4 Replace the memory cover and secure it with the screw. 5 Reinstall the battery pack, and reconnect the AC adaptor. 6 Turn on the computer. The computer automatically detects and reconfigures the total memory"
Posted on Sep 02, 2007
  • 244 Answers
SOURCE: All Drivers for Acer Aspire 3680
you can download from www.acerpanam.com
Posted on Oct 01, 2008
Geekman
  • 32281 Answers
SOURCE: Opening acer aspire 5050
The top and bottom covers are also held together with plactic catches.
After you remove the battery, CD/DVD drive and hard drive etc.
start near an openning and gently pull apart the top and bottom cases, you should hear a click as a catch releases, then continue to work around the edge fron this point.
Posted on Mar 06, 2009
  • 700 Answers
SOURCE: Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Posted on Apr 17, 2009
zohail
  • 1223 Answers
SOURCE: remove DVD on Acer Aspire 5315
could u pls kindly rate me if ur problem is FIXED now ! or is there anything else i can do for u
Regards
Posted on Apr 21, 2009
Try this link:
Apr 17, 2009 | Acer Computers & Internet
Fan blade noise
This is most of the time due to excessive dust covered on processor heat sink try cleaning in side with pressure air by removing keyboard.
Mar 13, 2009 | Acer Aspire 5050 Notebook
Acer Aspire RAM
There are 4 screws holding the cover on the bottom of the computer that allows access to the RAM modules. (This is the same cover that also covers the fan. The same cover with the ventilation slots.)
Simply remove the screws and lift the cover by the indent to the right of the battery lock.
Nov 22, 2008 | Acer Aspire 5720-4230 Notebook
Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Jul 30, 2008 | Acer Aspire 1640Z Notebook
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
Right-click button has collapst on bottom side. have to click at top of button
To disable Aspire 5100.
1. remove battery, harddrive.
2. open all cover on the back of laptop.
3. removed wireless antena cable from wireless card.
4. remove power cover (power cover is cover that have power button)
5. removed 2 screws on the back that hold lcd.
6. removed 4 screws that hold lcd. (now you can remove lcd).
7. remove 2 screws on top that hold uppercase from lowercase.
8. remove all screw on the back.
9. remove heat sink, and remove 1 screw under heat sink.
10. that's all, you can remove uppercase and repair it.
i hope this help you. good luck
Mar 22, 2008 | Acer Aspire 5100 Notebook
How to replace keyboard
1. Remove 3 screw from top of laptop. this screw hold power cover (cover which have power button).
2. Remove power cover.
3. remove 2 scews that hold keyboard.
4. that's all, you can take keyboard out from laptop.
i hope this will help
Mar 18, 2008 | Acer Aspire 5002WLMi Notebook
Broken connection on power jack
for Aspire 5100
follow this step.
from backside
1. remove battery
2. remove hard drive cover and hard drive
3. remove the thermal cover, remove wireless card and antena cable.
frontside.
1. remove the power button cover.
2. remove keyboard.
3. remove lcd cable, wireless antena.
4. remove the lcd screw (2 long screw and 2 short screw)
5. remove the lcd screw from the back side (2 short screw).
now the lcd is separated from laptop body.
from backside again,
1. remove fan, there are 2 screw that hold the fan
2. remove heatsink (4 very short screw)
3. remove all screws from backside, there is 1 screw hidden "under" heatsink. it's short scew (longer than heatsink screw).
from frontside, remove 2 screw on top part of the laptop body.
and than you can remove the uppercase now.
after you remove the uppercase, remove 2 screw that hold modem, and remove 1 screw (very short) on bottom part, it's close to touchpad button. remove power switch board and modem and then remove the speaker cable and mic cable.
that's all you can take out the motherboard.
note: just remember to use the correct screw when you put it back.
i hope this will help.
Feb 26, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5315-2153 Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
