Question about LG Flatron E2241vb-bn 22 Led Lcd Monitor 16 9 5 ms / E2241vb-bn
Remove stand REMOVE FOR STEND
1995 harley Dyna low rider kickstand removal/installation
To remove the stand, you'll need to block up the bike so it'll stay upright while the stand is removed.
Now, there are two ways to remove the stand.
If you want to remove it as an assembly, unhook/remove the spring, and remove the four bolts holding the bracket to the frame:
http://i.ebayimg.com/00/s/OTYwWDEyODA=/z/efIAAOxyx0JTfhs7/$_57.JPG
To remove just the stand's arm, leaving the bracket bolted to the frame, unhook/remove the spring, and remove the nut on the pivot, and the kickstand stop (the part with the squared off peg that fits into the bracket when the stand is down and weight is placed on the stand, when you lean the bike over onto it):
http://i.ebayimg.com/00/s/MjY3WDQwMA==/z/vdcAAOxyQfJTfNWR/$_12.JPG
May 26, 2014 | Harley Davidson Motorcycles
I need to remove the viewsonic VX2433wm stand.
mine has 4 silver screws running perpendicular to the stand shafts, remove the 2 pairs and the stand should slide out the bottom.
Mar 17, 2013 | ViewSonic VX2433WM 24 inch LCD Monitor
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
3) Remove the five screws shown in the diagram below. This will
4) Once you have removed all five screws holding the pedestal
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
How to remove stand
Just taken the stand off my LG 42LC2D. The stand is made of cast aluminum and has 2 long legs that insert into the base of the TV. So to remove the stand lay the TV on its screen and remove the two screws that are vertically in line next to the power socket the the 2 screws that are vertically in line under the RGB socket. The stand then pulls out from the bottom of the TV.
Dec 16, 2007 | LG 42LC2D 42 in. LCD HDTV
LG Flatron E2241vb-bn 22 Led Lcd Monitor 16 9 5 ms / E2241vb-bn Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
