Kenmore washer 26632
Timer
  • 157 Answers
I think the regulator which sets the timing has some problem. You need to show it to the technician.
Posted on Jul 23, 2013
How to remove the timer?
HERE IS A LINK TO YOUTUBE VIDEOS CONCERNING YOUR WASHER..... BUT I DIDNT SEE ANYTHING ABOUT A TIMER. I HAVE REPLACED KENMORE TIMERS....PULL OFF THE KNOB...
REMOVE THE SCREWS THAT HOLD DOWN THE COVER WHERE THE TIMER IS LOCATED.... ONCE YOU HAVE THE COVER OFF..... GET YOUR PHONE OR CAMERA AND TAKE A PICTURE OF WHERE ALL THE DIFFERENT COLORED WIRES ARE LOCATED...SO YOU WONT BE LOST WHEN YOU INSTALL THE NEW TIMER.
https://www.youtube.com/results?search_query=HOW+TO+REMOVE+A+TIMER+Kenmore+Series+70+Washer+Motor+387780
Dec 02, 2014 | Kenmore Series 70 Washer Motor 387780
WHAT HAPPENS IF A TIMER IS OUT ON KENMORE WASHER
you push the timer in and turn it to the setting you want,when you pull the timer knob out the washer should run
Jun 20, 2014 | Kenmore 24032\24036 Top Load Washer
My Kenmore 11020022012 washer stops prior to spinning cycle. If I manually turn the dial to spin, it will spin fine. Need help troubleshooting..
timer needs new electric motor to advance from rinse to spin cycle.
or alternately ,you can have your old timer taken out of your washer and sent out to be rebuilt or buy a new timer.
in any case , you will need a kenmore washing machine repairman to take out your old timer and send it away to be rebuilt and expect that to take 2 or 3 weeks
the timer rebuild used to cost$ 50.00 in 1993 and a new timer went for $110.00 to $129.00
for a sevice man to take out and reinstall a timer $60.00 to 100.00 labor
try to google.com or bing.com or ask.com-----and type in : kenmore washing machine,rebuilt timer. you will need the model number of the washer as well as the model number of the timer and the timer may have a different name that kenmore
also try typing in kenmore washer,new replacement timer
try call sears and see how much their service man wants to put in a new timer. I am sure prices have gone up since 1993
when I retired from the major appliance repair busness. i could do the timer remove & install, but I probably live 1000 miles from you.
another option: knowing that you will need to spend around $200.00 or more by the time you get a new timer installed
you might want to see how much lowes or home depot wants for their cheapest bottom of the line washer. that might be a good alternative as it allows you to get a new washer and buy an extended warantee so you dont get stuck with another 200.00 repair. I think they have washers starting at 289.95 only 90.00 morte that repairing your old washer which is going to run for how many more years before it again gives you trouble?
check out lowest prices on bottom of the line washers unelse you want to spend a lot on a fancy washer to make yourself happy.
you can shop on line by just google.com or bing.com and the name of the store. home depot, lowes, sears,walmart
and type in clothes washers.
Oct 08, 2013 | Kenmore Washing Machines
My Kenmore washer is not draining or rinsing
Check the lid down safety switch. On the lid there is a small spike that goes through a hole when the lid is down.
Under the hole is a switch that allows the timer to advance and the washer to spin only when the lid is down. Two screws hold the switch in place and the plastic switch will sometimes break and be hanging by the wires.
In other words, it is the timer. That is stopping the advance. You may have to replace the timer.
How to replace the timer in Kenmore top load washer
Aug 27, 2017 | Kenmore Washing Machines
How do you replace the timer in a Kenmore Washer Model 22622?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=41610396bdeaf9d724c8d6b9910df259
Basic Whirlpool / Kenmore washers may use one of two different timers. See the following Whirlpool / Kenmore Service Manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Assuming that you have the metal timer, You'll need to remove the timer knob. The easiest way is to hold the metal shaft that passes through the timer with a thin needle nosed pliers while un-screwing the knob.
Once the knob is off, it's a simple matter to unplug the connectors and remove the bolts holding the timer to the console.
Oct 21, 2010 | Kenmore 22622 Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
